AC POA valve
Old Oct 20, 2016 | 03:48 AM
rand5204's Avatar
AC POA valve
I'm starting to work on the AC system of my 70 442. It has been open for a long time so pretty much everything will need to be rebuilt/replaced. It appears that the original style POA valves are no longer available. Classic Air advertises that they can cut them open and rebuild them but my local AC guy with over 30 years experience is skeptical. Does anyone have any experienced with the results of this process?
Old Oct 20, 2016 | 05:38 AM
brown7373's Avatar
Classic Auto Air in Tampa can rebuild and re calibrate your POA for 134a, if you are using that.
Old Oct 20, 2016 | 07:18 AM
chip-powell's Avatar
I had a thread going about this earlier this summer if you care to do a search. Classic Air is the way to go. I converted my system over to R-134 and needed a new POA. The one that they sent out works perfectly.
Old Oct 20, 2016 | 07:30 AM
442Fred's Avatar
PM sent
Old Oct 21, 2016 | 05:47 PM
blakes7's Avatar
I used classic auto air of Tampa FL, they did a fantastic rebuild and adjustment job on my POA valve, the AC in my Delta Convertible is ICE COLD!!!
Old Oct 21, 2016 | 06:07 PM
"Banny" on this site says he can rebuild and calibrate them, too, and has them in stock.
Old Oct 22, 2016 | 06:08 AM
chopolds's Avatar
I did this myself for a friend's 70 Impala. Cut it apart, recalibrated it for 134. Works well. I did wind up building a compressed air "tester" for the unit, to check to see if it worked correctly, and didn't leak. Took all of an hour or 2.
hullinger
Sep 27, 2014 05:22 PM
Macadoo
Jun 22, 2014 05:50 PM
1970-W30
Aug 14, 2013 07:52 PM
Silchad
Sep 12, 2012 09:38 AM
Al Graaf
Apr 6, 2012 08:46 PM
