POA valve testing and calibration
A few of us were looking for this info a while back. Seems legit.
http://www.autoacforum.com/messagevi...threadid=16311
Nope, that's the right one, the valve just looks different without its outer case.
Here's the other thread that I've found with significant information on this subject.
There are other bits of information out there, but these two threads seems to have everything important in one place (okay, two places).
So you connect everything and it reads 28-32 for R12. Then turn the screw 1/4 turn CCW. That's it? No reading for the new pressure? Seems there ought to be a target pressure when set for 134A, not just 1/4 turn.
If you look at this picture, you can see he has a breaker bar and long extension sticking out of where the adjuster screw is:
(Incidentally, this picture shows how to check the valve without removing it from the car).
The screw and locknut are inside the valve, deep in the hole.
Open the high side and listen to the POA go "pop". the low side handwheel is closed and stays closed. Read the pressure on the low gauge. Should be 26 for 134a and 29 for r 12.
That's why I said that thread was the other useful one.
Hmm, that might be why the CSM says the valve is non-repairable and non-adjustable.
Chineseium gauge sets are cheap, and should be good enough for occasional use.
In your case, an old R12 set may be available very cheaply at a flea market or yard sale.
They're very good to have.
Cursed CSM!
That valve is adjustable also. I would be more concerned about the rust you see down in there.
1/4 to 1/2 turn CCW for a guestimate.
It would be best if you could rig up a test set like in the picture.
More info on testing can be found here:
https://classicoldsmobile.com/forums...2-cutlass.html
