POA valve testing and calibration
Old June 21st, 2014, 06:46 AM
Macadoo's Avatar
A few of us were looking for this info a while back. Seems legit.
http://www.autoacforum.com/messagevi...threadid=16311
Macadoo is offline
Old June 21st, 2014, 07:41 AM
Macadoo's Avatar
On further inspection, this seems to be a different POA valve. My bad.
Macadoo is offline
Old June 21st, 2014, 07:45 AM
Nope, that's the right one, the valve just looks different without its outer case.
Here's the other thread that I've found with significant information on this subject.
There are other bits of information out there, but these two threads seems to have everything important in one place (okay, two places).
MDchanic is offline
Old June 21st, 2014, 07:49 AM
Macadoo's Avatar
But I'm not seeing a screw with a locknut. Just something that looks like a very small nut. I'll check out the other thread. Thanks Eric.
Macadoo is offline
Old June 21st, 2014, 08:03 AM
brown7373's Avatar
So you connect everything and it reads 28-32 for R12. Then turn the screw 1/4 turn CCW. That's it? No reading for the new pressure? Seems there ought to be a target pressure when set for 134A, not just 1/4 turn.
brown7373 is offline
Old June 21st, 2014, 08:14 AM
The screw and locknut are inside the valve, deep in the hole.
If you look at this picture, you can see he has a breaker bar and long extension sticking out of where the adjuster screw is:
(Incidentally, this picture shows how to check the valve without removing it from the car).
MDchanic is offline
Old June 21st, 2014, 08:15 AM
Macadoo's Avatar
This is what I see....
[IMG][/IMG]
And in the diagram I don't see anything that would be a screw. But it does look like if I turn that nut ccw it would release pressure on the bellows.
[IMG][/IMG]
Macadoo is offline
Old June 21st, 2014, 08:19 AM
Macadoo's Avatar
Oh, deeper in there. Mmmkay.
Macadoo is offline
Old June 21st, 2014, 08:20 AM
Read the third post in the thread that I posted after yours:
Open the high side and listen to the POA go "pop". the low side handwheel is closed and stays closed. Read the pressure on the low gauge. Should be 26 for 134a and 29 for r 12.
R12 is 29psi, R134 is 26psi.
That's why I said that thread was the other useful one.
MDchanic is offline
Old June 21st, 2014, 08:22 AM
[IMG][/IMG]
Ahhhhhhh... Methinks you have one of the non-adjustable ones.
Apparently there are more non-adjustable valves on later cars, but it's really kinda random.
Maybe time for a junkyard run....
MDchanic is offline
Old June 21st, 2014, 08:26 AM
Macadoo's Avatar
I have to be honest, I don't have a setup for testing. I just want to get to the screw that turns 1/4 turn ccw
Macadoo is offline
Old June 21st, 2014, 08:27 AM
Macadoo's Avatar
Hmm, that might be why the CSM says the valve is non-repairable and non-adjustable.
Macadoo is offline
Old June 21st, 2014, 08:37 AM
Chineseium gauge sets are cheap, and should be good enough for occasional use.
In your case, an old R12 set may be available very cheaply at a flea market or yard sale.
They're very good to have.
Cursed CSM!
MDchanic is offline
Old June 21st, 2014, 11:52 AM
banny's Avatar
That valve is adjustable also. I would be more concerned about the rust you see down in there.
banny is offline
Old June 21st, 2014, 12:01 PM
banny's Avatar
Just remembered the replacements were also adjustable but a pita because you cant calibrate it with the air and gauges attached like you can with the originals
banny is offline
Old June 22nd, 2014, 01:45 PM
Lady72nRob71's Avatar
You just turn the nut - that is what I did.
26psi is a good target for 134a.
One of these years I will get my AC system finished...
Lady72nRob71 is offline
Old June 22nd, 2014, 03:33 PM
Macadoo's Avatar
1/4 turn then?
Macadoo is offline
Old June 22nd, 2014, 03:51 PM
Macadoo's Avatar
I keep checking....
Macadoo is offline
Old June 22nd, 2014, 04:25 PM
1/4 turn then?
1/4 to 1/2 turn CCW for a guestimate.
It would be best if you could rig up a test set like in the picture.
More info on testing can be found here:
https://classicoldsmobile.com/forums...2-cutlass.html
Old June 22nd, 2014, 05:50 PM
Macadoo's Avatar
Well we all know MAW. I'm introducing a new one; GEFN (good enough for now)
I'll start with a 1/4 turn. I'm guessing it would be better than nothing.
Macadoo is offline
toymobile
August 5th, 2015 04:10 PM
hullinger
September 27th, 2014 05:22 PM
1970-W30
August 14th, 2013 07:52 PM
Silchad
September 12th, 2012 09:38 AM
Al Graaf
April 6th, 2012 08:46 PM
Quick Reply: POA valve testing and calibration
