Hello Olds fans.
Please allow me to vent a little.
I just dropped off my carb to be rebuilt by a local expert
and he said the carb body needed to be replaced, threads
are badly worn at fuel line/filter point.
1970 Cutlass convertible 3 peed manual on floor.
Original QB code engine with original 7040253 carb.
Hello Olds fans.
I have to try to find a replacement.
Or, just have a helicoil installed in the fuel inlet.
they make a specific kit for the quadrajet maybe try everyday performance hes in CT and
or look online lots of rebuilders like sparkys or cliffs or DIY quadrajetparts is another online seller
I know that you already dropped the carb off, but I just thought that I would put this out there for future reference. I had the same problem 2 years ago for my quadrajet. At the time, I did not have the time to send it out because I was up in PA (where I used to store my Olds) and needed to get it back home in Maryland that day.
At the local home depot I found a newer type of plumber's tape (yes, plumber's tape) that is made to be used with fuel lines. Exposure to gas does not affect it at all. A few wraps on the gas line and it was able to screw onto the few threads that were left on the carb. It worked so well, I left it that way for the rest of the summer, just to see how it would hold up. Passed with flying colors.
I wouldn't call it a permanent fix, but it worked so well that the tape is now a part of my in car emergency tool box.
