Carb Blues
Old Apr 26, 2016 | 09:45 AM
jagwhire's Avatar
Carb Blues
Hello Olds fans.
Please allow me to vent a little.
I just dropped off my carb to be rebuilt by a local expert
and he said the carb body needed to be replaced, threads
are badly worn at fuel line/filter point.
1970 Cutlass convertible 3 peed manual on floor.
Original QB code engine with original 7040253 carb.
I have to try to find a replacement.
Picture 001
Old Apr 26, 2016 | 10:54 AM
Originally Posted by jagwhire
Hello Olds fans.
Or, just have a helicoil installed in the fuel inlet.
Old Apr 26, 2016 | 12:04 PM
marxjunk's Avatar
The fuel inlet repair has worked for 35 years..an expert would know that..take it somewhere else
I've had then fixed where they where so bad there was no threads even left
Old Apr 26, 2016 | 02:03 PM
jagwhire's Avatar
Thanks for the response guys. I mentioned a healicoil
and he said it won't last.
I'll try to find someone else.
Dave
Old Apr 26, 2016 | 02:28 PM
RetroRanger's Avatar
72 Olds CS
they make a specific kit for the quadrajet maybe try everyday performance hes in CT and
or look online lots of rebuilders like sparkys or cliffs or DIY quadrajetparts is another online seller
Old Apr 26, 2016 | 02:49 PM
jagwhire's Avatar
Thank you Retro<
Ill check out those businesses.
Dave
Old Apr 26, 2016 | 06:30 PM
marxjunk's Avatar
it is a valuable carb..use a reputable shop...even with a repair..its valuable, its a hard carb to get..
Old Apr 29, 2016 | 08:32 PM
jagwhire's Avatar
Thanks to all for the direction, dropped off my carb today to everyday performance for rebuild.
Right here in CT.
Have nice weekend and drive those oldsmobiles!
Dave
Old Apr 29, 2016 | 11:17 PM
z11375ss's Avatar
Senior Moment Member
Sweet car.
Old May 2, 2016 | 10:29 AM
chip-powell's Avatar
I know that you already dropped the carb off, but I just thought that I would put this out there for future reference. I had the same problem 2 years ago for my quadrajet. At the time, I did not have the time to send it out because I was up in PA (where I used to store my Olds) and needed to get it back home in Maryland that day.
At the local home depot I found a newer type of plumber's tape (yes, plumber's tape) that is made to be used with fuel lines. Exposure to gas does not affect it at all. A few wraps on the gas line and it was able to screw onto the few threads that were left on the carb. It worked so well, I left it that way for the rest of the summer, just to see how it would hold up. Passed with flying colors.
I wouldn't call it a permanent fix, but it worked so well that the tape is now a part of my in car emergency tool box.
Old May 3, 2016 | 03:58 PM
jagwhire's Avatar
chip, Thanks for tip.
When I pulled the carb there was some type of teflon tape
on the threads already. Thast when i knew there was a problem.
I should have it back this week.
Old May 9, 2016 | 07:01 AM
pcard's Avatar
70 Cutlass SX
Great looking car! If they do a good job could you post their contact information or URL.
Old May 9, 2016 | 09:35 AM
Octania's Avatar
Yeah, but that heli coil "won't last"
You will be lucky to get another 10-20 years out of it.
Old May 10, 2016 | 05:59 AM
jpc647's Avatar
Let us know how it works out.
I've got a Q-Jet i need glass beaded and rebuilt for a stock ish 72, maybe I'll consider the guys in the CT.
It's between them and Hobbs in Pelham.
I've had bad luck with Edelbrock, tuned it way rich and it's almost there. But I need someone who can rebuild the Q-Jet accordingly.
Old May 10, 2016 | 08:14 AM
jagwhire's Avatar
JPC, please call Ken at 860-218-5780 Everyday Performance.
I'm sure he can answer your carb questions.
Dave
Old May 11, 2016 | 05:55 AM
jpc647's Avatar
Dave
Thanks!
Please post back when you get your carb back, let us know how it runs and any issues, etc.
Driftr
Jun 24, 2011 09:39 AM
wolfman98
Jul 28, 2009 08:47 AM
chris weber
Mar 19, 2008 07:51 PM
GothamCity
Oct 19, 2007 01:27 PM
Ranzan
Mar 19, 2007 02:27 PM
