Radiator Question
Old Apr 28, 2016 | 07:58 PM
67Rocket's Avatar
Radiator Question
I just installed another radiator in my Cutlass and coolant is not circulating, the radiator cooled the donor car fine so I wouldn't think there would be any blockage. Could I have a air pocket some where in my cooling system? The radiator I removed cooled ok in cool weather but it was running hot with
the 455 and warmer outside temps. Thanks for all help.
Old Apr 28, 2016 | 08:23 PM
Magna86's Avatar
When you drained the coolant did you flush out the block with the hose? More than likely your waterpump is failing and needs replaced. The propeller could be rusted or coming off the shaft and not spinning. Having a blockage is rare.
Old Apr 28, 2016 | 08:28 PM
Thermostat condition / status?
Old Apr 29, 2016 | 05:11 AM
lemoldsnut's Avatar
When I fill the coolant in a empty system I always take the thermostat housing off and fill the block first. Then install a new thermostat and gasket and fill the radiator.
I am also thinking you have a stuck thermostat or a bad water pump. Of both
Old Apr 29, 2016 | 06:02 AM
67Rocket's Avatar
Thermostat is 160 and less than a year old but I am going to remove it and see what happens, the water pump moved the coolant with the other radiator. I think I am going to flush the system and try Red Line water wetter for the summer time after I get coolant circulating. Any body tried water wetter? Thanks!
Old Apr 29, 2016 | 01:09 PM
I had a thermostat that was just a month or so old fail in the closed position. It was one of those things I thought I might as well replace as I was was putting a new water pump on. Learned that new isn't always better. I installed the old one that I had taken out and it's been fine for years now.
Old Apr 29, 2016 | 03:52 PM
67Rocket's Avatar
I removed the almost new thermostat and problem solved. I hate thermostats because I have had so many problems with them over the years, it will be a cold day in hell before I put one back in my Cutlass. Thanks everybody.
Old Apr 29, 2016 | 09:31 PM
Glad you got it fixed!
This is not a good idea.
To save me from having to repeat things posted in the past, read this thread.
This post isn't too bad either.
Alex72cutty
Apr 21, 2015 10:30 AM
59Olds98
Aug 14, 2013 09:38 AM
g77rvd
May 13, 2011 11:29 AM
#1CutlassSupreme
Jun 11, 2008 02:03 PM
68Tom
May 13, 2008 11:40 AM
