"HF" vs. "XE" Wheels
Old May 2, 2016 | 04:17 PM
67442nut's Avatar
I have some "HF" and some "XE" wheels.
Can't really see what the physical difference is between the two.
Both are 14" x 6" and offset looks the same.
Does anyone know the difference?
Old May 2, 2016 | 09:39 PM
orange442's Avatar
Different years and date codes.
Old May 3, 2016 | 07:19 AM
Mikes442's Avatar
The XE a drum brake wheel for 1970 and the HF was a disc brake wheel from 1970. What are the 3 numbers on the inside where the tire goes?
Like 810, 795....
Old May 3, 2016 | 08:49 AM
orange442's Avatar
I was thinking the XE wheels were 70 disc wheels and the HF were 71-72 disc wheels.
Old May 3, 2016 | 12:48 PM
67442nut's Avatar
Both have the profile of a disc brake wheel.
I think the "HF" wheels were originally on a '67 Cutlass disc brake car.
A Chevelle site shows the "XE" wheel came on 1968 Chevelles.
Couldn't find anything else about an Olds application.
Two "XE" were stamped "MADE IN USA" N19 with "NT"near a lug hole.
Three "XE" were stamped "KELSEY CANADA" N14X6JJ, AL, 5 ? P12, K20.
One "XE" was stamped "KELSEY CANADA" D14X6JJ, AL, 2 ? 26T, K20.
The "K20" were in a triangular arrangement with "K 2" side by side and"0" centered below.
Question mark (?) represents some kind of symbol.
"HF" wheels had no stamping on inside of wheel, only at the valve stem.
One "HF" was stamped"K19 6".
One "HF" was stamped"M17 3".
One "HF" was stamped"M17 2", "20R".
Old May 3, 2016 | 01:02 PM
orange442's Avatar
NT is Norris Technologies, plant #1, 1969
K 20 is Kelsey, plant #2, 1970
K 19 is Kelsey, plant #1, 1969
M 17 is Motor Wheel, plant #1, 1967.
If there are other numbers on each side of valve stem they are the month and day of the year.
Old Feb 22, 2017 | 02:20 PM
OldsAl's Avatar
Xe
I would be interested in one of the 1970 XE wheels. What are you asking for them? Al
My442
Dec 26, 2017 05:08 PM
jim larson
Apr 1, 2016 02:13 PM
MDchanic
Wheels and Tires
22
Aug 4, 2011 10:23 AM
WTony
Jan 15, 2011 07:53 PM
