What battery have you had the best luck with ?
I've been using Interstate batteries in my '76 Cutlass since I purchased it. I'm now on my 3rd battery since 2008. The last one seems to have only lasted 2 summers. This spring I trickle charged it full, took my '76 out for a 20klm drive parked it in the garage, went out to start it up today and its dead again.
I'm thinking about switching brands and would like to know what batteries you guys have good luck with over the years and continue to have good luck with.
Eric
Eric
The dealer I bought my 442 from put a new Interstate battery in it right before he shipped it to me,it's been in the car since 2012. I do use a tender on it while it sits. Never had a problem with it,plus it has a flat top that you need for one of those "delco" battery toppers that I have on it. I use tenders on all my vehicles,all the time. I got 8 yrs out of my original Harley battery,the dealer told me they usually last about 4-5 yrs.
This may surprise you but Walmart. I read that several years ago in some battery comparison and decided to try them. So far so good although I can't tell you how long I have had them. I don't know who makes them.
X2. Been perfectly fine in my daily drivers. I do have an Optima in my truck and it's also been fine. I finally had to replace it after eight years or so.
I feel really lucky as most batteries work fine for me, all except Interstate which I will not buy. I buy AC Delco, WalMart but my favorite is Optima. Optima costs more but if you buy from Amazon they are more reasonable. I have one that is many years old (maybe about 10) and works as well now as ever. And there is no green/blue corrosion with Optima.
Just my opinion,
Mike
Just my opinion,
Mike
Thanks for all the quick replies, Chip yes my alternator is fine. I see the majority here seem to think the walmart brand are good batteries. I'm not going to bother bringing my Interstate back and pay the prorated warranty deal they have, I like the Intersate battery look ( green/white top, white case) however I feel its time to drop them. I'm going to go to the walmart website and have a looksie. Although I like The Optima's, just too expensive for me.
Eric
Eric
I run Toyota OEMs in my truck, they work for the five years they are rated for. Have had a yellow duralast out of Autozone on my 442, it has worked for ten years with low use. I run K mart batteries, whatever brand they are, on my Monte Carlo, but I think my lifetime warranty is probably dead now, and they last ten years or so with moderate use.
Keep it charged (as in don't leave it dead; the trickle chargers are over-rated) and keep it in at least a garage.
The Toyota ones do goop up the terminals. Think my just purchased Tahoe has a green interstate, it won't take charge, but I think that is the truck's terminals being insulated.
Be aware that the Optimas of today are NOT the same as the Optimas of years ago.
These used to be the favorite of off-roaders here in Arizona as they would hold up for many, many years in the heat and rough operation but in the past several years the quality has gone way downhill and it has been attributed to the fact they are now built offshore. Many folks have reported early failures, and the warranty has changed from 3 year free replacement and prorated after that to a two year replacement then no warranty at all beyond that. The local Costco stopped carrying them due to poor quality issues and so many returns.
I have one of the "old ones" in the Cutlass dated 2006 and it still works fine.
I usually just grab what ever from auto zone or advance auto they seem to last about a little longer then the warranty. But I never really thought about it the one in John deere 750 has got to be pushing 15 yrs. and when it's idling the red light is on . It's a diesel and I rarely use the lights. It's a sears die hard I think . I'll
have to check maybe its got a date.
Railguy
Railguy
It looks as though non of the Giant battery names are much good these days yet the prices are still out ther.
I had a look on the Walmart website here and they only show 1 brand, Sure Start, Sure Start Plus and Sure Start Maxx.
Prices range from $89, - $129.
Much cheaper than the Interstate and Optima's .
I'm thinking just the picking up the $89. one just for the summers. Is it really worth spending more than $89. just for summer use?
I never really gave batteries any thought, I just bought Interstate because of the look, so I'd like to ask you guys which one would you buy out of the 3 Sure Starts.
Eric
Eric
I will second Koda's AZ duralast gold. The one in the Cutlass will be 16 years old.
The OEM Delco in the Alero is still doing great! That one is 12.5 years old. Neither has been trickle charged, just unhooked from the negative side. Both get a slow charge for a couple of hours on spring start up!
My dad worked with some guys that worked at Delphi they said the Walmart high end batteries were built by Delphi. FYI Delphi is Delco.
Pat
Pat
Thanks guys, I've heard of the dura-last Pat, I believe Sears sells them here.
I'm really getting SICK of spending more money on the " use to be" respected name brands that are now apparently made off shore that don't last.
I wouldn't mind spending the extra money if they were in fact still made in the U.S or here in Canada, but I'm tired of getting ripped off by these companies.
Eric
Eric
I wouldn't be surprised if I found out that 99% of all batterys came from the same factory in China. Or the components to make them.
Railguy
I had a die hard in my gmc that I absolutely loved! I remember going with my dad to get the battery in 2008, when the truck was still my aunts. It just recently died, was still working great but I robbed it for a car that didn't like to start and then let it sit uncharged and I could never save it. Was still going strong before that though. Replaced it with an oriellys battery and have been less then happy but I do have another oriellys battery in my 66 that's a monster. Both were purchased new.
Here's what I do... I buy batteries from Costco, they come with a 2 year replacment warranty. I set a reminder on my phone for 18 months and exchange them when it goes off. They don't test them and you just pay whatever the price difference is. Last time I swapped the batteries in my truck it cost me 12 dollars. My truck kills a set of batteries every 3 to 4 years and I got tired of paying 200.00 every time they failed.
The WalMart batteries were top-rated by Consumer Reports about ten years ago (the time could be off - who can remember?), but I am under the impression that somewhere around five years ago they changed their manufacturer, and while they didn't go completely to crap, they are not as good as they were at the time.
I still buy them, mostly because they are cheap and easily available, and I haven't had a problem with one (ie: behavior outside of rational expectations) in the past ten years.
Went out yesterday put the key in ready to go nothing had to reboost. I have an old radio in this car and that's it nothing that is really pulling from the battery. I 've had problems with the last two Interstate Batteries, the first one lasted 5 months, dead in August. Returned for this one, been running for 2 summers, this spring doesn't want to stay charged. Ok it was -5 here yesterday and -10 overnight but that shouldn't affect the battery IMO.
Thanks for posting the possibilities,
Eric
I'm really leaning towards the Walmart Sure Start brand . We just had 20cm of snow dumped on us overnight and with the week ahead it looks like it won't be getting any better so I won't be going battery shopping just yet.
I tell ya, I won't be paying top dollar for name brand batteries going forward !!! "ta' hell with em". I'll keep the extra $$ in my pocket.
I have a car that I only drive about a month a year just to move the fluids around while it awaits my older son turning 16. As that day get nearer, I'll give the car a good tune up, flush all the fluids, a fresh set of tires, and a new battery.
No BS. The Sears Die Hard Gold battery in it is 20 years old. I've only recently been using a four bank tender on it about the last four years or so. But even before the tender, I would just disconnect it while the car sat.
[QUOTE=Local Hero;909096
No BS. The Sears Die Hard Gold battery in it is 20 years old. I've only recently been using a four bank tender on it about the last four years or so. But even before the tender, I would just disconnect it while the car sat.[/QUOTE]
I have been doing the same for years, It seems I've had some bad luck with the Interstate brand for some reason. The first one lasted ten years I was shocked.
The second one only went 5 months April-August, returned it, payed the $55.00 for a new one. Then this one only lasting 2 summers.
I'm not going to pay $90. prorated price for another at this point.
The walmart brand here has good reviews looking at them, especially now since most guys here have mentioned they are good. I have a week or so to decide. I'd really like the Yellow top Optima but for close to $300 bucks here I just can't dig that deep into my pocket anymore.
I have been buying batteries at Batteries Plus. No problems with them. I just bought a blem for the 70 4dr, $50. I switched to them when my boss bought a battery there. The old battery came from them. They Still honored the warranty even though he did not buy the battery. It was in the vehicle when he bought it.
Don W
Don W
Wal Mart here also. They regionally are still made by Delphi or Johnson Controls. They today are clearly marked to who manufactured them, JC here. The $100 battery in my 2004 Camry lasted nine years, replaced with another one of their $100 batteries, but core is a lot higher now.
#31
#32
A couple(few?) years ago my local O 'Reilly guy told me about Optima going the el cheapo route & not to buy them any more. I've not had to buy any batteries in a few years but this is a good thread!!
#33
Here's some battery info from a recent discussion on the local Jeep Club web site:
http://www.virtualjeepclub.com/showt...-a-New-Battery
#34
I have an awesome update on my end here, My wife called Pro Oil and spoke with the owner this morning they are our Interstate battery dealer here.
They are going to replace it free of charge this time since we are good customers and we bring all our cars to them.
They warranty stays the same 1 year free replacement and the 5 year Performance warranty prorated.
I hope to have better luck with this new one !!
Thanks to all for posting you experiences to date, this will definitely help me on my next battery purchase.
I know that Walmart batteries will be going in our G8's when needed !!
Cheers
Eric
Cheers
Eric
#38
Also, not to be an ***, but where do you guys go that what the battery looks like matters? Is that a judged thing? I kind of thought tires, brakes, shocks, batteries, bulbs and other things that wear out were ok to replace with equivalent. I like seeing modern maintenance replacements on these cars; it's a testament to they're still here and still putting miles on the road.
#39
#40
No need to use a battery topper. Buy a reproduction (R71S) from Antique Auto Battery in Hudson, Ohio. Get the sealed version. Mine's 7-1/2 years old and holds a charge better than any battery I've ever used.
Last edited by BlackGold; April 6th, 2016 at 03:11 PM. Reason: Corrected battery age.
