M22 and reverse lights...
Old May 5, 2016 | 05:54 AM
sammy's Avatar
Sammy70 455 Supreme
how were the reverse lights hooked up a M22 out of a 1971 442?....the top rod looks like it links back into the column?......thanks,
File Type: jpeg
Old May 5, 2016 | 06:24 AM
Yes, the back-drive linkage from the reverse lever actuates the back-up light switch on the steering column.
Old May 5, 2016 | 06:26 AM
sammy's Avatar
Sammy70 455 Supreme
Thanks Eric!
Old May 5, 2016 | 06:35 AM
You're welcome!
The same movement rotates the column collar and allows the transmission to be locked in Reverse when the ignition is locked.
Old May 5, 2016 | 07:27 AM
As a current automotive assembly employee, one thing I love about old big 3 stuff is the variety of options you could get. Putting the column shift linkage in, even for floor shift, and just driving it at a different point was an inspired solution to offer options at low impact to the shop.
Old May 5, 2016 | 07:48 AM
My442's Avatar
Looks like this:
File Type: gif
Old May 5, 2016 | 10:08 AM
sammy's Avatar
Sammy70 455 Supreme
Perfect...thank you sir^^^^^
Old May 5, 2016 | 12:06 PM
You may be giving them too much credit.
Actually, prior to the federal mandate for steering column and shifter locks, GM used a different backup light switch on the trans itself. I think it even took them a year or two to realize that with the backdrive linkage in place, they could actually continue to use the column-mounted NSS for the floor-shifted manual trans.
Pokefase
23
Jun 6, 2015 05:31 AM
fast67vellen2o
Jun 29, 2014 12:28 PM
Pacman1507
Jan 8, 2010 11:07 AM
bluecutlass
Oct 26, 2009 07:38 AM
kimberlies7
Oct 10, 2009 03:45 PM
