330 Timing chain
Old Apr 19, 2020 | 03:06 PM
1988coreym's Avatar
330 Timing chain
Replacing the timing chain on a 330 Olds. Bolt in Cam gear Very Tight. Any Suggestions ?
Old Apr 19, 2020 | 03:22 PM
Sugar Bear's Avatar
1. Try heating it, spraying penetrating oil on it while warm and let it cool or
2. Use an impact gun, or
3. If it is severely stuck you could pack the area with rags and cut the gear off leaving the bolt intact to work on.
An impact gun shouldn't have a problem breaking it loose. Be patient and work with it, a broken bolt in the camshaft would be a headache.
Good luck!!!
Cutlass Fan
Oct 12, 2016 12:08 PM
lass4ken
Oct 16, 2013 06:08 AM
SIPLOWGUY
Apr 16, 2010 06:24 PM
bluecutlass
Aug 25, 2009 04:01 AM
millwrightrice
Jul 27, 2007 02:58 PM
