Going rate for 3:91's
Old Apr 23, 2017 | 11:08 PM
What's the going rate for a decent set of O type 3:91 ring and pinion? How much with the posi unit? (no carrier).
Old Apr 24, 2017 | 03:13 AM
jensenracing77's Avatar
I am terrible with the terminology of rear end parts... When you say "with the posi unit" no carrier, What does that mean? I sold a 3.91 setup with the posi unit in 2012 for $600. The gears were very nice. I would bet they would go for a little more now but not sure.
Old Apr 24, 2017 | 07:02 AM
66-3X2 442's Avatar
The carrier is the posi unit or the open unit.
Old Apr 24, 2017 | 10:06 AM
Eric, here's a pic of the posi unit with the ring gear. I also have the pinion gear. I want 3:91's for my '69 (ring and pinion only), but I would consider selling this set with the posi to someone restoring a '68-70 W30/W31. I need to get a good look at the splines to get a count to see whether it is the '67-68 31 spline, or '69-70 28 spline. I was told that it was a '69 31 spline, but in '69 they went to the 28 spline axles with better metallurgy.
Old Apr 24, 2017 | 12:54 PM
I read on the old Chebucto e-mail list nearly 20 years ago that the metallurgy change occurred in 1970 along with the different bearing design.
Old Apr 24, 2017 | 02:18 PM
Ancient Iron's Avatar
What is a whole 3.91 rear end assembly worth???
Old Apr 24, 2017 | 04:29 PM
An SJ with a nice housing should bring at least $850+ unrebuilt but working, A TO with a nice housing would likely be in the $1200+ range.
Old Apr 24, 2017 | 08:43 PM
Somewhere, in one of my books is where I read it. I agree with the bearing change in 1970, that is mentioned in Supercars Unlimited "442 by the Numbers" booklet, which also indicates that the '70 was a higher strength unit.
Old Apr 24, 2017 | 08:55 PM
Cool, I didn't know that info was actually published. I learned it from first hand experience - I currently have one of each version of the O-Type 12 bolt: a 1968 standard 28 spline, a 1968 Heavy Duty 31 spline, and a 1970 28 spline. I have a spreadsheet with all of the data I could gather, such as bearing part numbers and dimensions, seal part numbers, bolt sizes, carrier casting numbers, etc.
Old Apr 24, 2017 | 09:10 PM
What does your spreadsheet have for this unit? I am trying to confirm what Monzaz (Jim), told me, that it is a '69 31 spline, but it may be my lack of correct info as I was sure that '69 & 70 was the 28 spline.
Old Apr 25, 2017 | 04:40 AM
joesw31's Avatar
That posi is 31 splines for years 67 and 68 application. In 1969 they went to a 28 spline axle shaft and the casting number for that posi is "588". Further, in 1969 they used two different axle shafts a heavy duty axle shaft, and a non-heavy duty application. Each axle shaft has a different casting number. In general, the heavy duty axles have white paint on them. The same also applies to 1970. However, 1970 used a different axle shaft bearing. Also, for 1969, the ring gear bolts were changed from right hand thread to left hand thread. Hope this helps.
Old Apr 25, 2017 | 09:55 AM
So, this "672" posi is for 1967-'68 Olds rears with 31 spline axles? Therefore the ring and pinion will not directly swap into a '69 due to the '69-70 having a larger ring gear? (My '69 has a TY rear under it, currently housing 3:42's). I ordered a RH 7/16-20 bolt from Rock Auto just so I could check to see what threads it had RH or LH. Oddly enough, I pulled this posi from a '69 LeMans about 35 years ago when I had a '66 GTO with 3:08's not knowing back then what it took to put more aggressive gears into a car, nor the fact that this wasn't even a Pontiac gear set, as pointed out by Jim. Thanks everyone for their help. Now to figure out a value for a '67-68 posi rear!
Old Apr 25, 2017 | 11:46 AM
11971four4two's Avatar
MOTORHEAD
I would think a 1967- 68 31 spline axle would be stronger. Just not as common or as easy to find parts for
Old Apr 25, 2017 | 11:51 AM
MOTORHEAD
HERE ARE A FEW PICS 672 vs 588 carriers 301 vs 342 ratios
THE gears should be 8.5 10 bolt with 12 bolt cover IE the same fitment. The carriers and left hand / right hand bolts etc... will be different for 69 - 70 and other mobiles
value???
I was told my 31 spline TO axle was worth $xxxx
not sure if that is realistic for a quick sale
but that is as low as i will go on mine
Old Apr 25, 2017 | 02:37 PM
joesw31's Avatar
Your ring and pinion will work fine in your 69 W31 "588' posi with no problem. You just need the correct bolts. Ever thought of 4.33's? I learned the hard way about ring gear bolts years ago...
Old Apr 25, 2017 | 02:49 PM
joesw31's Avatar
value???
Those bearing caps are installed reverse on this diff. The arrows on the caps should be facing outward.
Old Apr 25, 2017 | 03:05 PM
I have a set, sometime in the future, if I ever get his thing on the road again, I may try them for one summer. My car was factory 4:33 equipped, owner number 2 had them removed by an Olds dealership back in the 70's when he was commuting to Junior College, hence the 3:42's in there now.
Old Apr 25, 2017 | 03:17 PM
joesw31's Avatar
I ran a set of 4.33's for while in my W31. The 308 cam liked the 4.33's. Not the best street gear. You should be fine with those 3.91's.
Old Apr 25, 2017 | 03:22 PM
Mr Shifty Sidney's Avatar
Thanks to all for the good info.
​​​​​​​Don W
Old Apr 25, 2017 | 03:43 PM
The ring gear is stamped: 11A43 GM LH, which is telling me the tooth count on the gears, General Motors, and is LH for left hand threads? Pinion also has 11A43 GM plus DT and 394705 243 332 if it helps I.D. which set that it is.
Old Apr 25, 2017 | 04:12 PM
joesw31's Avatar
The 68 ring gear should be right hand thread if it wasn't changed. The posi should have a Julian date, the ring gear Julian date, and the pinion as well. 243 or 332 can be the Julian date.
Old Apr 25, 2017 | 05:50 PM
As joesw31 said, it's a 31 spline O-Type posi carrier.
Unfortunately, I do not have one of those - my 31 spline O-Type is a TL code 3.42 rear with an open carrier, casting number 359.
Old Apr 27, 2017 | 09:04 AM
Anybody have one 7/16-20 right hand bolt that they can sell me? The one That I ordered from Rock Auto was a left hand bolt, so I still want to make sure of what I have before ordering a set. Thanks.
Old Apr 27, 2017 | 12:56 PM
66-3X2 442's Avatar
If you're just checking bolt size and thread count,the hardware store has that size. Just sayin.
Old Apr 27, 2017 | 08:23 PM
No longer have any local hardware stores, and Home Depot didn't have any.
MDchanic
Suspension & Handling
Jun 9, 2016 05:55 PM
young olds
Apr 5, 2014 09:46 AM
Blackpage
Body work
48
Feb 13, 2012 01:41 PM
Gunfreak25
Apr 22, 2011 12:41 PM
BosMobile
May 28, 2009 08:48 PM
