Olds 350 fuel pump issues
Old Apr 4, 2017 | 08:23 AM
Cameron Boomer's Avatar
I have a ? The fuel pump that we had on the motor isn't pumping the gas, so we got a brand new one but it was bad do you think we should try a electric fuel pump or get another manual fuel pump to try it out.
Old Apr 4, 2017 | 08:35 AM
toymobile's Avatar
Have you checked the RUBBER lines at the tank and just under cowl area also at the pump???
Last resort is electric IMO.
Engine taken apart lately?? Fuel pump eccentric may be lose??
Good luck
Johny
Old Apr 4, 2017 | 09:39 AM
Good luck
Johny
yes the engine was rebuilt we're going to try a different fuel pump but if that doesn't work we will have to see if it's something else.
Old Apr 4, 2017 | 09:57 AM
toymobile's Avatar
With the fuel pump out of the way take a screw driver and feel if the fuel eccentric is lose.
Good luck
Johnny
Old Apr 4, 2017 | 10:01 AM
Good luck
Johnny
will try that
Old Apr 4, 2017 | 10:26 AM
Crazy question, you are installing it with the fittings on top?
Old Apr 4, 2017 | 10:43 AM
the motor is in the car but the fuel pump just isn't getting gas up to the carburetor
Old Apr 4, 2017 | 12:46 PM
RetroRanger's Avatar
72 Olds CS
oc means in this orientation
Old Apr 4, 2017 | 12:51 PM
And here's a pic showing how the pump arm rides on the eccentric that is bolted to the front of the camshaft. Hopefully you didn't leave that off during the rebuild.
Old Apr 4, 2017 | 01:53 PM
thanks
RenderPit
Ninety-Eight
Aug 6, 2015 04:55 PM
doby
Oct 30, 2013 09:20 PM
HonestDave
Aug 31, 2012 01:23 PM
sshriber
Mar 22, 2010 06:16 PM
Dutch
Jul 20, 2008 08:52 AM
