64 Olds Ninety Eight: Fuel Leak at Fuel Filter/Pump?
Old Mar 26, 2012 | 08:15 AM
RenderPit's Avatar
Cruizin
Hey guys,
When the car sits for a couple days without being started, it leaks fuel for a couple minutes once started back up.
It's right at the block, and looks like it's coming from the fuel pump/filter? I would guess that there is a seal/gasket in there that is worn out, and once it warms up, it seals up again.
This seems like a pretty easy fix but:
Has anyone had this issue before?
Anything I should be aware of before I start taking things apart?
Are parts readily available at NAPA?
I'll try to get some video/pics posted later on, but any help is greatly appreciated.
Old Mar 28, 2012 | 08:55 AM
Tedd Thompson's Avatar
If the leak is at the fuel pump diaphragm this can or is a potential dangerous situation . Often when a fuel pump goes bad gas leaks inside the crankcase and an internal explosion can occur. Does your oil smell of gas? If so do not drive your car till you have replaced the pump.I would try your local parts houses first but if they don't USA Parts Supply Has rebuilds aviable with a core charge part# S3 900L.....Tedd
Old Mar 28, 2012 | 09:47 AM
RenderPit's Avatar
Cruizin
I'll check into it a little more tonight. Thanks for the tip!!
Old Apr 15, 2012 | 10:52 AM
RenderPit's Avatar
Cruizin
So I've got the pump apart. I see a couple ripped gaskets and seals and I'm sure the filter could be replaced.
The problem I'm having is not being able to find a rebuild kit or even a fully rebuilt pump. When I look in the Parts USA catalog, 900L says it's for a 330 & 425... I have a 394, which I thought was the only engine option in the 98 that year...?
I can give them a call tomorrow to figure it out I suppose.
*EDIT: The diaphragm seal seemed to be well intact, so I'm hopeful that fuel was not leaking into the crankcase. The main leak I saw was gasket around the glass bowl. That one is pretty shredded.
Old Apr 15, 2012 | 11:59 AM
RenderPit's Avatar
Cruizin
Here are pics of the two most damaged areas: The glass bowl gasket, and this torn seal to the bottom of the fuel pump.
Old Apr 15, 2012 | 12:37 PM
Rickman48's Avatar
If you take them to a OLD, independant auto parts store, thats been in business over 20 years, with a parts guy OVER 30, you might find some loose gaskets that size!!
Old Apr 15, 2012 | 01:40 PM
RenderPit's Avatar
Cruizin
that's what i was thinking. Most of those types are closed on Sunday, so i'll make some calls tomorrow.
Old Apr 15, 2012 | 03:18 PM
dlh61olds's Avatar
http://maritimedragracing.com/then_a...otive___se.htm
Will sell you the correct rebuild kit
or rebuild yours. Good prices and great customer service.
Dave
Old Apr 15, 2012 | 03:53 PM
RenderPit's Avatar
Cruizin
rock on Dave! Thanks for the lead!
Old Apr 29, 2012 | 04:54 PM
RenderPit's Avatar
Cruizin
I sent it out to those guys!
They said the kit was $40, but for another $45 they'd rebuild it for me.
Not a bad deal at all.
Now on to fixing the overtightened valve cover on the pass side
Old May 12, 2012 | 02:27 PM
RenderPit's Avatar
Cruizin
Then and Now did a great job!!!
Old May 14, 2012 | 08:08 AM
RenderPit's Avatar
Cruizin
Old Jun 9, 2012 | 05:38 PM
RenderPit's Avatar
Cruizin
Makes the rest of my engine bay look old and crusty...
Old Aug 6, 2015 | 04:55 PM
63Olds88Hearse's Avatar
me tooo!
im having the exact same problem with the exact same part, mines a 63 Olds 88 with the 394 sky rocket engine, im afraid to drive it cuz whenever i start it up it bleeds fuel from the pump,
fburkle
Dec 2, 2011 07:21 AM
66ninetyeightls
Ninety-Eight
Sep 16, 2011 06:38 PM
Danny Boy
Jul 25, 2011 08:20 AM
skubydobdo
Ninety-Eight
Aug 13, 2008 10:43 PM
