fuel pump issues
Old Oct 25, 2013 | 03:36 PM
doby's Avatar
fuel pump issues
1991 cutlass supreme 3.4 5 speed manual trans.car was starting at early summer. 3 days ago i turned the key on and the fuel pump didn't pump. Checked the relays and they were good. Changed the fuel pump and still no fuel. I have one leg of power at the plug from car harness which I believe runs the sending unit. What else am I missing?
Old Oct 26, 2013 | 12:09 PM
jcdynamic88's Avatar
fuel pump problem
maybe your ground, I haven't seen it on your model but mid 90's gm cars have a problem with a ground terminal that is next to driver's sill plate.usually the power windows don't work either.
Old Oct 30, 2013 | 09:20 PM
MarkDavid's Avatar
weren`t some cars fuel pump ran off the ignition module . Car would still get fire , but fuel pump side of module would be bad and not run pump ? Also on some certain vehicles , faulty oil pressure sending unit would not let fump run . May not be part of your vehicle , but it is something to check into . That 3.4 you have , isn`t that the o/h cam bad boy v6 ? If so , and as unique as they were , i would not be suprised if either one is part of your system !! Good luck .
HonestDave
Aug 31, 2012 01:23 PM
Nor Cal Andy
Mar 29, 2012 07:27 PM
stlbluesbrother
Mar 21, 2011 03:24 PM
sshriber
Mar 22, 2010 06:16 PM
Dutch
Jul 20, 2008 08:52 AM
