394 fuel pump with vacum pump
Old Mar 22, 2010 | 10:28 AM
sshriber's Avatar
Hello all,
I am redoing my 62 Super 88 and it is an A/C car. It has an additional vacum pump on top of the fuel pump to augment the vacum for the system when needed. I am not doing an original restoration and will be replacing the brakes with a dual master cylinder and newer power assist. Do I need to use the fuel pump with the vacum pump on it? Or can I get away with just a fuel pump? Thanks
Old Mar 22, 2010 | 01:33 PM
rocketraider's Avatar
Oldsdruid
You should be able to find a vacuum reducing valve and tap into manifold vacuum. That might save having to hunt down a double action pump.
Or you could always block off the f/p mounting and run an electric pump since you're not going for originality.
Old Mar 22, 2010 | 05:32 PM
dlh61olds's Avatar
You can buy the rebuild kit or have the pump rebuilt by
www.then-now.com. Your pump is most likely # 6585.
Your A/C and heater controls also work off the vacuum.
Dave Holt
Old Mar 22, 2010 | 06:16 PM
sshriber's Avatar
Thanks Dave. It is a 6585> That is a great site and I will get incontact with them.
Olds1957
Ninety-Eight
Dec 1, 2014 06:26 AM
Jacks62
Mar 18, 2014 07:31 AM
craftsman1956
Jul 12, 2010 08:33 PM
rocwal
Jan 30, 2010 10:29 AM
abram
Nov 7, 2009 11:46 AM
