Odd control arm
Old Apr 23, 2017 | 10:53 AM
brandon reynolds's Avatar
Odd control arm
Going through my control arms and found this pair with bolts instead of nuts. Anyone no why these are different? I only part 68-72 so it has to be one of those. Thanks Brandon
Old Apr 23, 2017 | 02:44 PM
Those ball joints don't look right.
Old Apr 23, 2017 | 03:11 PM
Indy_68_S's Avatar
I think that's the Chevy (& maybe B or P? ) setup with the bolts. I have a bagged set of the bolts & big washers that I acquired somehow that says "68-72 Control Arm". If those came off an Olds, maybe someone replaced the shaft & nuts with the C style parts ??
Old Apr 23, 2017 | 03:22 PM
CRUZN 66's Avatar
Olds Fever
Factory setup for 66... My 442 has that style shaft setup and I believe my 67 does as well... I also have a spare set of control arms like that and I never parted out any 68-72 front suspensions (only 66 & 67)...
Old Apr 23, 2017 | 03:23 PM
I never parted a 66
Old Apr 23, 2017 | 03:54 PM
CRUZN 66's Avatar
Olds Fever
Originally Posted by brandon reynolds
I never parted a 66
Any possibility early 68 may have used it from the factory? If not, someone obviously must have used them as replacements on their 68/72... But it is an Oldsmobile design control arm...
Old Apr 23, 2017 | 04:12 PM
I did part some 68s
Old Apr 23, 2017 | 06:17 PM
oldolds88's Avatar
same as my 65
Old Apr 23, 2017 | 08:16 PM
68442's Avatar
68-72 cutlass/442 used the nut style. This style(Bolt) was used on Chevelle's for sure, Chevelle never used the nut style in these years. I don't know about Pontiac/Buick.
Either style will fit the same arms. so if they were replaced some one could use Either style
Old Apr 24, 2017 | 04:15 AM
rand5204's Avatar
I bought a front end rebuild kit from PST suspensions last year for my 70 442. The cross shafts with the bolts in the picture are exactly what I got. I knew they were wrong and didn't use them. Too late now to send them back. At least now I know they are for Chevelle. Buyer beware on these at PST..
Old Apr 24, 2017 | 05:52 PM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Early 68 442 Cutlass have the nut as well. Those are Chevelle upper shafts. The A arm stamping is generic but no idea why Chevy uses a different set up?
Someone likely installed them on one of the Olds you parted. They will fit and function the same.
http://www.ss396.com/chevelle/BPX-8542.html
oldzy
Dec 19, 2011 06:43 AM
Jamesbo
Mar 3, 2009 05:15 PM
don71
Oct 30, 2008 05:24 AM
MeanGrnGt
Brakes/Hydraulic Systems
Jul 20, 2008 05:34 PM
OldsMotion
Nov 16, 2006 04:45 AM
