How the heck does this happen???
Old Mar 26, 2017 | 08:36 AM
My wife complained that her 1985 D88 was stalling at low speeds. Removed the air cleaner this morning and found this. Yes, that is an idle mixture screw sitting on the intake.
To quote Holly Hunter from Die Hard 2, "why do these things keep happening to us?"
Old Mar 26, 2017 | 08:42 AM
cjsdad's Avatar
How did that engine even run right with that mixture screw backed out a few turns, let alone far enough to fall out? Your Mrs must be pretty tolerant of a rough running engine.
Old Mar 26, 2017 | 08:48 AM
Actually, the CCC system compensated by changing the duty cycle of the mixture control solenoid. It was surging a little, but really didn't run poorly.
Old Mar 26, 2017 | 08:50 AM
Ha haha, been a while since I've seen that. Make sure the spring has enough tension to keep it in place. The only other cause is a squirrel thats upset with your...
Old Mar 26, 2017 | 08:54 AM
Yup, my thought exactly.
Old Mar 26, 2017 | 09:25 AM
ELY442's Avatar
[QUOTE=joe_padavano;1002426]My wife complained that her 1985 D88 was stalling at low speeds. Removed the air cleaner this morning and found this. Yes, that is an idle mixture screw sitting on the intake.
Its Bonnie Bedelia.
Old Mar 26, 2017 | 09:40 AM
Originally Posted by ELY442
Its Bonnie Bedelia.
Yes, it was. DOH!
Old Mar 26, 2017 | 09:52 AM
AJFink's Avatar
Looks like the spring is to short did a piece break off? If I remember right new springs will go to the end of the point.
Old Mar 26, 2017 | 09:56 AM
Nope. Both ends are ground flat, as they should be. I suspect the spring has just compressed a little and taken a set.
Old Mar 26, 2017 | 10:16 AM
oldspackrat's Avatar
The Russians did it!
Old Mar 26, 2017 | 11:21 AM
A dab of red Loctite will prevent that from happening again.
LEGAL DISCLAIMER
for those unfamiliar with working on carburetors: This is a joke. Do not attempt.
Old Mar 26, 2017 | 11:25 AM
Bfg's Avatar
Bfg
You need to set up a surveillance camera!
Old Mar 26, 2017 | 11:58 AM
I was thinking TIG welder...
Old Mar 26, 2017 | 01:16 PM
ELY442's Avatar
No no no, you got it all wrong. Lubricate the threads with JB Weld.
Old Mar 26, 2017 | 01:35 PM
Tedd Thompson's Avatar
It's the same gremlins that hide the tool you were just using, got um at my house too.... Tedd
Old Mar 26, 2017 | 01:56 PM
Oh, man. Don't get me started about THAT!
I just chalk that up to my advanced CRS disease... Can't Remember $**t!
Old Mar 26, 2017 | 03:50 PM
Wow. That's a new one on me.
I agree with the obvious - probably a weak spring. I can't imagine anything else unscrewing that screw that many turns, except maybe a leprechaun, or perhaps even Murphy himself, Heaven protect us!
Old Mar 26, 2017 | 03:53 PM
A pissed off squirrel...
Old Mar 26, 2017 | 03:56 PM
Okay, so if the squirrel turns screws consistently counterclockwise when he's PO'd, can I catch him, feed him, and make him happy, so that he turns things clockwise, then have him assemble an engine for me?
Old Mar 26, 2017 | 06:14 PM
Chris J's Avatar
Damn squirrels
Could be the ghost of a PO
Old Mar 27, 2017 | 05:20 AM
Old Mar 27, 2017 | 05:34 AM
Old Mar 29, 2017 | 03:12 PM
RonFX's Avatar
Guys:
Same sort of thing happened to me a couple years ago. I have a Holley 4150 carb on my big block, it started running really rough, I pulled the carb and found one of the jets laying in the fuel bowl, never ever saw that happen before.
Ron
chrisneu68olds
Oct 20, 2014 02:24 PM
yamahondarider
Body work
Oct 23, 2013 06:13 PM
1965cutlassragtop
Jun 27, 2011 06:27 PM
mlouderback
Jan 30, 2011 07:47 AM
BIGJERR
Sep 21, 2009 10:38 AM
