Anyone else have this option? Pulse wiper on shift handle.
Old Feb 11, 2014 | 08:03 AM
oldspackrat's Avatar
I had heard of this option a long time ago & a few years ago, finally found one on a '70 98 convertible. This car had to have every option available that year & it was a real shame to see it in a yard.
The pulse wiper option was only available on cars with a column shift due to the button placement. I removed the handle & wiper motor from the car, but nothing else as I'm sure the 98 harness is different than a Cutlass. The wiper motor got hot & melted the unique cover & part of the internals. This motor is specific to this option I believe. I think I remember reading that when you pressed the button, the wipers would sweep back & forth 3 times maybe?
A year or so I found a similar set up on a big Buick & grabbed the handle from that car also.
I have heard it was available on the Cutlass line but I have never seen one.
Just wanted to post some pix to inform others.
Old Feb 11, 2014 | 08:12 AM
66400's Avatar
It was offered only on 70-71 fullsize Olds and Toros. Also 71-73 fullsize Buicks and Rivieras.
Did you get the wiper switch also that might be different than norm.
Henry
Old Feb 11, 2014 | 08:33 AM
Henry,
I did not know it was only offered on the big cars, that would explain why I've never seen it on a cutlass. Thanks for your input.
I did not think to grab the switch & the car is long gone.
Old Feb 14, 2014 | 07:07 AM
rocketraider's Avatar
Oldsdruid
It was offered on Cutlass at least one year between 70-72 but can't remember which year. I've had one of the Olds shift levers for years but not the rest of it.
Shift lever is different between carlines according to the parts books.
Seems I remember if you pressed the button to first detent it would sweep one time, like the later "mist" position. Push it to second detent and it would activate the washer and sweep several times.
Old Feb 14, 2014 | 08:06 AM
66400's Avatar
Rocketraider inspired a little more research on my part and I found listings for 71 and 72 Cutlass and Buick Skylarks with shift lever control pulse wipers.
Henry
Old Feb 14, 2014 | 08:39 AM
Henry - You did?? I'd sure like to see that. The CD3 option for the wiper/washer is not a 'pulse' system - it was called a 'controlled' washer / wiper system because it was driver controlled, not on a timed pulse system like today's cars. For Olds A body the washer/wiper control in the shift lever was ONLY offered I believe in 1971. Are you sure you're not mistaking the 71/72 'sweep' feature? The sweep feature was only offered on B/C cars. The following quote from the 1972 'What's News about the Seventy-Twos product information brochure. When the driver pressed the wiper button to the 'Mist' position (down) this would allow the wipers to make a one sweep, then park again. It was not offered on the Cutlass lineup though.
This new feature, standard on all the Full-Size models, is especially useful when following traffic on wet pavement or in very light rain. It replaces the former optional Shift-Lever - Controlled Washer / Wiper (DC3). The windshield washer control remains below the wiper switch.
Scott - if you have the turn signal indicator with the Cruise feature there was a guy on the site about a month or so ago looking for one. BTW what happened to that plastic cover?
Old Feb 14, 2014 | 08:43 AM
Allan H, (BlueVista) had one on his VC. Dang! I believe it was 71 so I have to go modify a post now....
Old Feb 14, 2014 | 08:46 AM
66400's Avatar
Looked up in a Hollander interchange for wiper motors and get a list for 71-72 calling it a wiper, with shift lever controlled.
Henry
Old Feb 14, 2014 | 09:13 AM
For A body?
Old Feb 14, 2014 | 10:23 AM
I know I'm looking for a 67 one. I *THINK* it's the same.
Old Feb 14, 2014 | 11:36 AM
Allan,
That cover was like that when I pulled it from the car. I assume something got real hot in the wiper motor? or somewhere close & melted it all together. I had to pry/break the cover to get it off the motor.
Old Feb 14, 2014 | 05:50 PM
66400's Avatar
For A body?
Yes for the A body 71-72 Cutlass and Buick Skylarks.
Henry
Old Feb 14, 2014 | 05:58 PM
Thanks Henry, can you please post a scanned copy of that or give me a link so I can access that info?
Old Feb 15, 2014 | 02:38 PM
Eric Anderson's Avatar
http://bit.ly/1fpAQiS
Here is one that I saw on e-bay. He says it came out of a 70 toro.
Old Feb 15, 2014 | 03:16 PM
Eric, thanks. I know they were an option on 70-71 big cars, and A bodies. I'm still looking for the elusive 72 A body application. Reason being I'd love to equip my 72 Cutlass with as many 72 OEM options as I can during its rebuild.
Old Feb 15, 2014 | 03:50 PM
Octania's Avatar
Cool find
Last time seen... NEVER.
Old Feb 15, 2014 | 04:16 PM
I'll keep a look out Allen. Anything special you are looking for that you don't have yet?
Old Feb 15, 2014 | 05:01 PM
66400's Avatar
Take a look in the owners manual, it may have operating instructions for it.
Henry
Old Feb 15, 2014 | 05:04 PM
66400's Avatar
Originally Posted by Octania
Cool find
I'll bet you have seen them but just didn't see them!
Henry
Old Feb 15, 2014 | 05:29 PM
Originally Posted by 66400
Take a look in the owners manual, it may have operating instructions for it. Henry
A very reasonable suggestion which I took to heart. It was not there, nor was it in the Assembly Manual, CSM or Fisher Manual for any of the A body cars.
You seem know me well Eric. I have almost everything that could be had for the 72. I'm not putting AC in the car though because it's just not warranted up here, and with PW's the flow through with all 4 sides down is wonderful. I'll sure let you know if something pops up though! Thank you.
Old Jul 17, 2016 | 12:16 PM
Mroldsmobilefrommass's Avatar
demand washer
This was a very rare option. I remember driving a new demo (70 98) with this. I was an Olds parts manager til 79. I do not remember ever getting a call for anything to do with it. I posted a few pages from olds/ buick parts catalog.Also the washer pump was a different part number, also pic.
Old Jul 17, 2016 | 01:14 PM
marxjunk's Avatar
on chevelles too...prob the most coveted option on a chevelle...and never seen either.
ive seen pics..but nothing in person..and prob only saw 2 in pics for a chevelle in my life...always looking too..always
never saw one in a cutlass...have seen a couple in big buicks
Old Jul 17, 2016 | 01:26 PM
2blu442's Avatar
Here's an old thread with pictures of a 1971 Vista Cruiser with this option.
John
https://classicoldsmobile.com/forums...1970-72-a.html
Old Jul 17, 2016 | 06:16 PM
anthonyP's Avatar
Seen the Cutlass column shifter wiper/wash feature in a brochure, but never in a car. Must be very rare, almost as rare as the '69 Chevelle options for the rear tire traction spray and headlamp washers. I've seen traction fluid holders/wheel well spray nozzles on a '69 SS 396/375 car, but never the headlamp spray cleaners. The options were only installed on 268 and 45 Chevelle's, respectively.
Old Jul 17, 2016 | 07:08 PM
Oldsdruid
Didn't know Chevelle could have these, and always thought the headlight washers were only available on Caprice/Impala with hidden headlamps (68-69). We learn something new every day!
Old Jul 17, 2016 | 07:37 PM
cherokeepeople's Avatar
i have seen headlamp washers on a 69 rs camaro it was in a junk yard and i took em off.i think i still have em.
Old Jul 19, 2016 | 12:04 PM
not avail. on A bodies.
Notice there is no part Nr. for motors with wash control like the 4939202 is for big cars, P.S. (when talking about B & C bodys, I 've always called them by their initials, BC or big cars.) Anyhow, I don't recall ever hearing about any A having this, so, more proof is in the lever itself. NO levers for the A with wash control, like no motors, etc. JUST wasn't avail. in the A bodys. ALSO, The price book lists the motor number as only interchange with Buick. NO Chevys, Ponts, or even Cads. I attached a pic of the levers for you to see. Don't beat yourself up looking for one cause they don't exist. NOT factory, anyhow.
Old Jul 19, 2016 | 01:33 PM
My mistake
I just looked at the photo 2blu442 posted. I never have seen, or heard of this on an A body. I was so sure, I read the catalog wrong. Went back and looked again, and 71 all t/wheel models this was avail.,A body included. As far as the motors go, A body used a different motor than, B,C. So, 71-72 A used 4939675 and that Nr is only olds,buick. Chevy must have used different set up if they had this. It really don't make sense to think someone would change the whole column, and motor & pump assy just for this. The harness for turn signal is different on tilt/non tilt where they plug in.
Old Jul 19, 2016 | 01:48 PM
1971 Oldsmobile option codes
Code CD3 for this option.
oldspackrat
Mar 12, 2015 06:34 PM
wizard
Nov 22, 2012 06:13 AM
droptopron
Apr 15, 2012 04:50 AM
2blu442
Jan 3, 2010 05:28 PM
GoodOldsGuyDougie
Feb 20, 2009 11:58 AM
