Does anyone else have a washer pump like this?
Old Apr 2, 2012 | 05:40 PM
droptopron's Avatar
delete
Question Does anyone else have a washer pump like this?
I got a replacement but it doesn't match up. This is on my '70 Cutlass.
The one I got only has one plus (to the left in the pic) but mine has the wires on the right as well. Can I get a replacement anyplace?
Old Apr 2, 2012 | 06:09 PM
starfire's Avatar
I've been wrong before, but I'm pretty sure the wires to the right go to the wiper motor, not the washer pump.
Old Apr 3, 2012 | 07:17 AM
jag1886's Avatar
http://www.restorationservice.net/contact.htm Call this guy he totally restored my wiper motor and washer pump on my 65. Nice guy fast turn around.
Old Apr 3, 2012 | 09:58 AM
You would be correct. When you remove the pump from the motor, the connector on the right remains with the motor.
Old Apr 8, 2012 | 09:15 AM
sachseDD's Avatar
Ha, I know it does not answer your question, but check out mine....
Someone seems to have attached a secound one since the one that has to be in this model got lost/not working
Old Apr 8, 2012 | 09:37 AM
That is a completely normal looking washer pump, as used an essentially every GM car for about 20 years.
As Joe says, perhaps you are confusing the wiper motor for the pump.
So, my first response would be, "Sounds like you've already got a replacement."
Photos of the replacement might help us to be sure.
Well, it didn't get lost, since you've posted a picture of it.
As for not working, its connected to the tubing, but not to the wiring, and the replacement pump near the reservoir is pumping fluid through the original pump to the nozzles.
You could fix it if you wanted to (it's usually just bad valve diaphragms), but if what you've got works, there's really no need to.
Old Apr 8, 2012 | 09:42 AM
sachseDD's Avatar
Hi Eric, hmmmm.. I can't tell if it works because I have no idea so far how to start it. The former owner placed a new switch for the wipers, but not for the washer and the **** I presumed to be the correct one does not have any effect on nothing.... I first will have to get closer in it...
Old Apr 8, 2012 | 10:04 AM
Normally, you just press inward on the wiper switch, or there's a separate button next to the wiper switch (or right in the middle on earlier models).
If your car has been changed, then anything is possible.
Old Apr 15, 2012 | 03:47 AM
sachseDD's Avatar
https://classicoldsmobile.com/forums...-pictures.html
Eric, looks like it's not only the pump....
Old Apr 15, 2012 | 04:50 AM
m371961's Avatar
The 2 wire plug operates a coil that ingages the pump mechanism. The motor for wipers runs through the 3 wire plug. If the pump mechanism is still in there, (under the plastic cover held on by a c-clip), you can get a rebuild kit from fusick.
costpenn
Aug 29, 2018 11:42 AM
jag1886
Dec 4, 2017 08:45 PM
dynamic63
Apr 10, 2014 09:53 AM
4door!cutlass
Mar 27, 2014 02:48 PM
DennisG.
Jan 6, 2012 08:37 PM
