1959 olds 98
Old Feb 1, 2014 | 12:06 AM
rd3cafe's Avatar
1959 olds 98
hi restoring our 59 2dr 98 ,can any one tell us if there is a later model brake master cylinder that mounts on the firewall that will work for our car ?thanks brad
Old Feb 1, 2014 | 04:42 AM
Oldsmaniac's Avatar
Not sure but 1960 used a different setup than the 59 so you may be able to swap that system over to the 59...
Old Feb 1, 2014 | 06:58 AM
394man's Avatar
There are a number of specialists who can do a very competent job of rebuilding the original. two different units are used: Factory power brake equipped cars use the Delco Moraine unit. Dealer installed PB is the Bendix Treadle-Vac unit (Which may also come in some factory equipped cars). They look similar, but share no parts. If I were going to convert to a firewall mounted system (With dual MC), I'd start with a pedal assy. from a non power brake equipped car, which will start you out with the correct geometry & pushrod (Which will have to be modified).
Old Feb 1, 2014 | 11:30 AM
johns59super88's Avatar
I'm curious. Why do you want to convert to a firewall MC?i. I rebuilt my MC located in the depths of the engine bay and other than being a PITA location, it worked out fine.
Old Feb 1, 2014 | 02:41 PM
lazy394's Avatar
I also rebuilt my Treadle vac, but am concerned with the single circuit master. The boys at the brake shop here said they could make a system to fit in the original location but use a new remote booster and dual circuit master. This means you can utilize the existing pedal assembly , hide the booster in the driver fender ( as long as you don't have the Autronic eye) and mount a new dual circuit master under the steering box out of sight.
The only thing to over come is the way the original actuating rod is attached by a cup formed in the rubber of the brake pedal pad.
Also the firewall has the punchouts for the Caddy etc master / booster that mounts above the steering box. You may be able to use the pedal assembly from another car that uses that mounting point.
Old Feb 2, 2014 | 12:35 PM
rd3cafe's Avatar
hi our thoughts were about upgrading mc to a dual circuit system. fire wall mounted mc would also make any maintanance in the future easier .will look at a friends 59 cadillac and see if it will work ,thanks for all your suggestions. brad
RingLeader1
Ninety-Eight
22
Feb 17, 2018 05:44 PM
Dean
May 16, 2010 05:21 PM
jlkoldsman
Cars Wanted
Oct 15, 2008 04:57 AM
59-59-59
Apr 13, 2008 07:16 AM
langy
Sep 14, 2007 01:36 AM
