Hood Doesn't Raise Very High
Old Jan 19, 2014 | 11:17 PM
z11375ss's Avatar
Senior Moment Member
Just curious. Does anyone else have this problem? The hood lifts up to a point where the hinges have a tab on them that do not let it raise any higher. It is a bear to work on because it is lower than a "regular" raised hood. My friends 69 raises nice and high. Do I have some kind of crazy hinges? Thanks in advance for the info. If anyone has hinges for sale I would be interested in mint pair for a 68 Cutlass.
Old Jan 19, 2014 | 11:25 PM
olds1968's Avatar
member
Unfortunately this is a one year thing I bump my head on mine all the time. If you want you can modify to the later 69-72 three bolt hood hinges or try and find a dual bolt pattern fenders.
Old Jan 19, 2014 | 11:36 PM
z11375ss's Avatar
So it's a one year snafu? I think I'll make the switch to 69 hinges. Anyone have any in vgc for sale?
Old Jan 20, 2014 | 05:00 AM
allyolds68's Avatar
I have a set but do you have a dual pattern fender? You realize it's not a simple swap, right? The hood holes on the 69 hinge do not line up with the 68 hood. They have to be elongated to fit. The set I have are slightly elongated but need further work to make the hood adjustable front to back.
Old Jan 20, 2014 | 05:40 AM
Nilsson's Avatar
Wear a helmet while working under the hood, problem solved.
Old Jan 20, 2014 | 05:45 AM
allyolds68's Avatar
If you build up enough scar tissue it doesn't seem as bad each time
Old Jan 20, 2014 | 05:58 AM
Professur's Avatar
I'm kinda grateful the hood on my 2 B bodies doesn't have a high angle. If it went any higher, I'd need to jump up on the bumper to reach it.
Old Jan 20, 2014 | 06:35 AM
Unfortunately, EVERYONE with a 68 has this problem.
Of course, the 69 hood raises higher, but the hood tooth will still get you every time!
Old Jan 20, 2014 | 07:56 AM
z11375ss's Avatar
Thanks for the input. The 68s will stay. At least now I know what's up.
Old Jan 20, 2014 | 08:01 AM
Yeah, and it's NOT your hood...
BADDA BING!
Old Jan 20, 2014 | 08:18 AM
jensenracing77's Avatar
Just be glad it is not a 61 or 62. They are even worse than 68. First step in the service manual for many things is to "remove hood" I almost have to remove the hood just to adjust the idle on the Jetfire.
Old Jan 20, 2014 | 08:54 AM
z11375ss's Avatar
BADDA BING!
Ha!
Old Jan 20, 2014 | 09:35 AM
Octania's Avatar
Welcome to the '68 owner's club
Here's your head bandage.
Wear it with pride.
Old Jan 20, 2014 | 09:44 AM
Tom442's Avatar
We feel your pain (really).
Old Jan 20, 2014 | 10:22 AM
olds1968's Avatar
member
I'm always having fun with family and coworkers when they want to see what I'm doing under the hood and I tell them to take a peek, and once they are done they end up with a bruise on the back of their head. lol you still want to see what I'm doing.
Old Jan 20, 2014 | 10:26 AM
RROLDSX's Avatar
I cut pieces of kid's pool noodles and fit them on the hood latch and center tooth (cut piece along the side). It pads the inevitable...
Old Jan 20, 2014 | 10:28 AM
442craig's Avatar
I knew that plate in my head would come in handy!
Old Jan 20, 2014 | 01:51 PM
tru-blue 442's Avatar
Old School Olds
I used to do this working on the 69.
If it's neon colored, you will see it
right before you whack your head, sometimes.
Old Jan 24, 2014 | 09:16 PM
copper128's Avatar
Lt. Buzzkill (ret.)
I know what you mean.
I put a neon orange foam noodle over the winch cable in my enclosed trailer after I tripped over it a couple times.
I still trip over it, but it doesn't hurt my ankles as bad now
Old Jan 25, 2014 | 06:30 AM
young olds's Avatar
X2, they barely open at all
Old Jan 25, 2014 | 05:23 PM
Yellowstatue's Avatar
If you don't like wearing a helmet, try standing on your knees!!
Old Jan 25, 2014 | 06:20 PM
z11375ss's Avatar
Then you can't reach the motor. I've actually tried this.
Old Jan 25, 2014 | 06:23 PM
coppercutlass's Avatar
Chevy budget Olds powered
What stops the hood is it a bump lower on the moving parts or a tab up towards the top on an arm if that makes sense. Im sure you can modify your hinges and make your own stop. Its been a while since I had hinges., you could buy some "junk" ones to fiddle with and mod.
Old Jan 25, 2014 | 06:43 PM
76olds's Avatar
Hookers under Hood
Lol, If copper can't come up with a fix then no one can just add tequila . Coopercutlass the MacGyver of all olds MacGyver's. Put-r-ther Copper!!!
Old Jan 25, 2014 | 06:44 PM
z11375ss's Avatar
The hinges I have are in perfect condition. They just don't let the hood open as far as my buddy's 69. I like the way that hood works. We were scratching our heads the other night about this hood. At least now I know it's correct and not a one off problem or the wrong hinges. What do you have Copper? A fiberglass hood with pins?
Old Jan 25, 2014 | 06:49 PM
acutally right now my car has no fenders or hood lol sold em. I did have the fiberglass fenders and pin on hood but im going back to steel fenders which I got cheap of course lol and a flat hood with hinges. I miss not being able to open my hood at local hang outs since usually there is no place to put my hood. I did however find out that glass fenders and hood are worth a tenth and a half in the 1/4. Plus I needed an excuse to paint my car. I though you needed more work room which is one thing I did love about the fiberglass lift off hood. Not to mention driving around town with the hood off and the non drop base air cleaner just to get more looks lol.
Old Jan 25, 2014 | 06:55 PM
z11375ss's Avatar
I got a ticket for that when I was a kid. Showing off in a 69 Chevelle with a nice looking small block. Unsafe vehicle if I remember right.
Old Jan 25, 2014 | 07:02 PM
Knock on wood I have never got pulled over in my cutlass and I do some seriously spirited driving. Elgin is I guess super strict on sound rules im surprised I never got pulled over as usually you can hear me 3 blocks away. I think since its a "classic" I get away with it lol. I think elgin is more after guys with 26's and pumping bass heavy music.
Old Jan 26, 2014 | 06:59 AM
76olds's Avatar
Hookers under Hood
Its embarrassing to get pulled over when the wifes feet are up on the dash cruzin through a small community heading up to the trailer lol . Didn't have time to put her seat belt on, had time to put the hood on thou .
Old Jan 27, 2014 | 09:47 AM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Ill take the low rise hood over that dam tongue ~ any day!
dschallock
Suspension & Handling
30
Sep 15, 2016 04:42 PM
bigjaythe1st
May 8, 2012 05:45 PM
Ddbord
46
Apr 22, 2010 07:48 PM
ctrain22
Dec 16, 2009 03:01 PM
Bobsw32
Apr 5, 2009 11:59 PM
