64 Cutlass frame swap
Old Feb 2, 2014 | 01:00 PM
PatrickF85's Avatar
ROCKET MADMAN
Can anyone tell me what years can interchange the frame on my 64 Cutlass. Will a 4 door 67 cutlass frame be the same? Will some thing before 73 match? Thanx for ur help.
Old Feb 2, 2014 | 02:02 PM
dc2x4drvr's Avatar
No, depends. I'm pretty sure you'll need a 64/65 Olds frame. Iirc it's either a Buick or Pontiac of the same year that interchanges.
Old Feb 2, 2014 | 03:46 PM
Octania's Avatar
Generally speaking, 2dr and 4dr models have a different wheelbase therefore different frames. Nothing a torch and welder can't fix, but the less work the better, right?
Old Feb 2, 2014 | 04:52 PM
oldstata's Avatar
Justin
Check with 2blue442 I am sure he could measure some frames might even have one but I thought 64/65 had same frames between two and four doors
Edit: look on bro442 under frames the measurements are there it says 64/65 except vista cruiser
Old Feb 2, 2014 | 05:48 PM
442scotty's Avatar
64-65 cutlass 2dr and 4dr are the same. 66/67 will not work. 65/66 buick skylark will work. Pontiac and Chev will not work.
Old Feb 2, 2014 | 06:56 PM
1964f-85's Avatar
I have a 65 GTO frame under mine, fir perfectly.
Old Feb 2, 2014 | 07:16 PM
dc2x4drvr's Avatar
Good info, I was under the impression that the Poncho frame was configured differently forward of the front crossmember, were any mods required for the bumper brackets, etc. to bolt up?
Old Feb 3, 2014 | 08:24 AM
Actually, only for the 1968-77 model years. The 64-67 cars all used a 115" wheel base (except the VC and Buick SportWagon). The 1978-88 cars all used a 108" wheel base (except the ElCo).
Old Feb 3, 2014 | 06:59 PM
1964f-85's Avatar
No issues front to back, bumper brackets, lower motor mounts, and my 64 cross member all worked perfectly. I was suprised how easy it was to swap.
Old Feb 3, 2014 | 07:36 PM
442scotty's Avatar
Good to know. I thought the Pontiac frame was shorter at the back end.
Old Feb 4, 2014 | 03:33 AM
J-(Chicago)'s Avatar
Seasoned beater pilot.
Have a 64 cutlass frame here about 5 hours Northwest of you.
oldsmobilty
Sep 27, 2012 04:26 PM
sixty9olds
Jun 14, 2011 06:43 PM
1969goatman
Aug 30, 2010 07:44 PM
DJMatthews
Dec 5, 2006 01:28 PM
