To Frame off or not to frame off...
Old Dec 4, 2006 | 07:31 AM
DJMatthews's Avatar
that is the question.
I have a 1970 cutlass convertible. Trunk gone. Quarter used a case of bondo. Inner/outers probably shot. Passenger floor has a tin rivited in. Other than that the car is fine. One body shop says he can do the work, but suggests doing a frame off. Another shop says, he can do the work, but says i shouldnt do a frame off if i plan to drive the car.
No Frame Off
        For Frame off
              What is a novice to do?
              Old Dec 4, 2006 | 09:33 AM
              bjtstarfire's Avatar
              It's a personal choice that you need to make on your own - you have the facts just lay them out and see what you can live with (i.e. cost benefit).
              If the frame is in good shape then forgo the frame off unless you want to have it blasted and painted...
              Old Dec 4, 2006 | 05:16 PM
              rockethound's Avatar
              first of all it is a very easy, every one well tell you not to for veriuse resons.
              but like bjtsarfire said its up to you. if you can do alot of the disasebly your self even strip the paint. you will save your self a boat load of money. check with your body shop the would probably want to do the body repairs first bifore taking it off the frame.mine was a hard top so i did mine first before body work. either way you will need to now how to renforce the door openings because its not a hard top. i took the body off the frame in my 22' by 18' garage then took the rolling frame and had it sand blasted then took it and had it primed and rubber caoted . coast for sand blasting and paint was about six hundred dollars. nd to boot mine is a driver thats what they were made for was to drive in my mind.
              Old Dec 5, 2006 | 01:28 PM
              ImWired's Avatar
              If the body is that punky you could start looking for another shell and finish the frame while your looking.
              ImWired
              oldspackrat
              Dec 21, 2012 08:27 PM
              oldsmobilty
              Sep 27, 2012 04:26 PM
              sixty9olds
              Jun 14, 2011 06:43 PM
              Gary's 2 442-S
              Nov 18, 2008 04:08 AM
              Want-A-Vert
              Mar 30, 2007 08:00 PM
