Type o rear end fit?
Old Feb 9, 2014 | 05:58 AM
PKHHBN's Avatar
Hi guys I have a 72 442 with a 10bolt rear, I also have a 1970 type o rear with a good posi in it, Question is will the type o posi unit fit in the 10bolt rear already in the car. Thanks paul
Old Feb 9, 2014 | 07:23 AM
dmullin's Avatar
azure blue 442
As far as I understand, your oem rear is an 8.5 chev 10 bolt.
Different carrier.
The whole assembly would fit of course, except for the different pinion yoke/rear u-joint.
Old Feb 9, 2014 | 08:13 AM
oldsmobiledave's Avatar
correction
Different carrier.
Your understanding is wrong. When did the Type O become a Chevy? Show me a Chevy that uses the Type O bolt in axles.
You can swap the entire Type O differential into your car knowing that you will need a new driveshaft or you can buy the correct posi carrier & gear set of your choice for your current 8.5" 10 bolt.
Old Feb 9, 2014 | 08:46 AM
66-3X2 442's Avatar
Why would you change out the 8.5 corporate rear for an O type? The 8.5 rear axle is superior to the O type and parts are readily available for the 8.5.
The O type only has 10 bolts holding the ring gear and only has a 12 bolt cover.
Old Feb 9, 2014 | 05:52 PM
dmullin's Avatar
azure blue 442
Some people are looking for a type o for correct restorations.
They are somewhat rare, and expensive to modify with little parts
availability as previously stated.
If it has gearing in it you like, use it as is. My o type has been reliable for the 17 years I've owned it.
Making a driveshaft for the o shouldn't be expensive.
If you need to change ratios sell the o type and put the money in the chev 10 bolt.
Old Feb 9, 2014 | 07:23 PM
66-3X2 442's Avatar
He has a 72 that never came with a 12 bolt type O rear axles. They came with 8.5 10 bolt corporate rear axles and were not just Chevy axles. You can't even buy a ring and pinion gear set for a 12 bolt O axle. That's why I asked why change the correct rear for an incorrect rear that's not as strong as the OEM axle.
Old Feb 10, 2014 | 07:25 AM
dc2x4drvr's Avatar
Sell the Type O, rebuild your 8.5..
Old Feb 10, 2014 | 08:54 AM
Just so we're all clear, the 1971-72 ten bolt is a "corporate" (as in "Chevy") 8.5 axle. Other than the use of bolt-in axles instead of C-clip axles, all parts of this axle interchange with other 8.5 Chevy axle parts. The Type O, despite also using ten bolts to hold an 8.5" ring gear (though the Type O uses different bolt sizes than the Chevy), shares NOTHING with the corporate axle. Other than brake backing plates, nothing interchanges.
Old Feb 10, 2014 | 11:24 AM
The posi clutches and S spring will interchange, also, but yeah, they are really totally different rear ends.
Old Feb 10, 2014 | 04:57 PM
dmullin's Avatar
azure blue 442
I promise I will never substitute the word chevy for the word corporate again.
Old Feb 15, 2014 | 06:23 AM
Tim305's Avatar
1969 cutlass convertible
I'm looking to convert my o type to a posi 342 but can't find the parts if anyone can suggest where I can find them.
Old Feb 15, 2014 | 06:27 AM
66-3X2 442's Avatar
Good luck,unless something has changed,they are not making any gear sets new @ this time. You can buy a converted Phord 8.8 posi unit from some vendors. Used is going to be your best bet or you can look @ the 3.42 posi rear axle I have for sale in the parts for sale section.
Old Feb 19, 2014 | 05:14 PM
Tim305's Avatar
I called supercars unlimited today. FYI they said they will have new gears for the o in May. 3:42 at least , No price yet but not cheap.
Old Feb 19, 2014 | 05:17 PM
66-3X2 442's Avatar
Good Luck with that. Ask 507OLDS how many dates he's been given.
Topless72
Nov 22, 2020 11:01 AM
350TurBRO
Sep 12, 2014 11:52 AM
MightyMouse61
Drivetrain/Differentials
Feb 27, 2011 05:00 PM
Aron Nance
Sep 14, 2010 05:37 AM
Qwik71442
May 26, 2010 10:58 AM
