top inoperative
Old Feb 1, 2014 | 06:53 AM
grouchyandugly's Avatar
top inoperative
hi....need help (physical, not mentally.....)
about to buy a 1964 olds dynamic 88 convertible.
but the top will not go down. moving the up/down switch does nothing.
unable to find the dirtyword fuse for it, at least looking under the dash.
also, when the engine runs, if the up/down switch is then moved, the
engine shuts off.
I definitely positively absoulutely would appreciate any help/comment/opinions on this dumb dirtyword cotton-picking snot-sucking problem.
thanks
G&U
Old Feb 1, 2014 | 07:05 AM
Octania's Avatar
Messing with a switch that kills the motor probably won't help much.
Rather than look for a fuse, which is probably a circuit breaker under the hood, may not help much either, if the switch is acting as you describe.
Can you get a wiring diagram for the car?
Going by my experience with later top pumps, and ASSUMING your system is electro-hydraulic - the pump will have 2 large wires. Feeding 12V to one wire makes it go one way, other wire goes the other way.
So, bypass all the fusing and switching trouble spots and run your own 12V hot wire back to the pump. Distach the connector, feed your 12V into the wire of your choice, and see what happens. If that still does not make it go, then the electrohydraulic unit must be faulty.
Old Feb 1, 2014 | 07:22 AM
top inoperative
wow. thanks for that info. the pump motor does have 2 big
wires going to it. I do not have a wiring diagram, as I have
not traded for it at this point in time; however that will change
this afternoon as I will make a deal on it. at least the top is
UP and not down (especially in this weird global warming we
have....)
thanks again
G&U
Old Feb 1, 2014 | 10:27 AM
m371961's Avatar
Octania gives good info. Circuit breaker on my 65 98 is located on firewall between master cylinder and inner fenderwell. Get a service manual, may find wiring diagram at wildaboutcars.com, they have manuals in sections for download, but nothing beats your own copy.
Old Feb 2, 2014 | 05:49 AM
top not co-operating
thanks.
bought the car yesterday. now I gotttttttta go get it.
then a couple days before I check it out.
humorous? last night about 2100 I ran over what I
thought was a Possum on our dark country road....
about 10 seconds later I found out I had hit a
SKUNK!! I had been sleepy....but woke up fast !!
thanks
G&U
Old Feb 2, 2014 | 06:12 AM
Octania's Avatar
Old Feb 3, 2014 | 06:22 AM
skunk
ha.
enjoyed that.
and my dumb dirtyword cotton-picking snot-sucking finger-licking olds
STILL smells of "skunk"
((at least no one around me will complain of my b.o. !!)
thanks
G&U
GoBigRed
Brakes/Hydraulic Systems
15
Oct 5, 2015 01:00 PM
Hal
Nov 25, 2012 02:59 PM
ctreutel
Oct 24, 2010 03:25 PM
1983oldsmobiledelta
Body work
Sep 19, 2010 07:15 PM
Jamesbo
Jan 21, 2010 05:23 AM
