how to make hard top when you have vinyl top
Old Sep 18, 2010 | 04:48 PM
1983oldsmobiledelta's Avatar
how to convert vinyl top to hard top its on a 1983 delta 88 would it look right and do you just have to remove the vinyl and there you go any help plz thanks
Old Sep 18, 2010 | 06:18 PM
ent72olds's Avatar
Registered Luser
Remove top, remove the glue, pray there's no rust, do whatever bodywork needs to be done(usually, cars with tops from the factory weren't finished properly underneath, being they would be covered anyway),then paint! To answer quicker, no, it's not a matter of just taking it off....
Old Sep 18, 2010 | 06:23 PM
how would they not be properly finished underneath what would i have to fix are do
Old Sep 18, 2010 | 06:35 PM
TripDeuces's Avatar
Usually the body seam between the roof and 'C' pillar is left rough with a solder joint. You need some Bondo, primer and prep work.
Old Sep 18, 2010 | 07:00 PM
how would i fix that like what tools and how hard would it be
Old Sep 18, 2010 | 07:05 PM
TripDeuces's Avatar
Reread my post young Skywalker....................Bondo, primer, prep work and paint. That's how you fix it. Since I don't know your skill set I can't tell you how hard it would be.
Old Sep 18, 2010 | 07:21 PM
64Olds98's Avatar
Also, hardtop typically refers to pillarless cars, and if you're working on the car in your picture, you've got a problem there.
Old Sep 18, 2010 | 07:27 PM
what do you mean sorry i dont know nothing bout the hardtop and vinyl tops
Old Sep 18, 2010 | 07:48 PM
rocketraider's Avatar
Oldsdruid
He's thinking hard top = a hard painted metal roof instead of a soft vinyl top.
Plenty of Deltas came without them. I can't remember for sure if the rear window mouldings are different between vinyl and non vinyl on Deltas like they are on Cutlasses and Ninety Eights. If they are you'll need mouldings to cover up the gap and probably clips to hold them on.
What Trip is talking about is the seam where the roof panel meets the quarter panel, between the rear door and the back window. On vinyl top jobs, the factory often did not metal finish that seam to the same quality they would on a non-vinyl car, since the vinyl roof would cover it up. Feel around right behind the rear door, up toward the top edge and see if you can feel a sunk in area. Sometimes you can see it in the vinyl.
You pull the vinyl roof cover off, you'll have to fill the sunk in area with body filler and finish and prime it, then paint it. Don't be surprised if you find very thin paint and surface rust on the roof itself under the vinyl cover.
Old Sep 19, 2010 | 07:46 AM
64Olds98's Avatar
I guessed this, but just wanted to clarify what was being asked. I was just reading this thread and it shows what could be under that vinyl though that car has a few extra years outside.
Old Sep 19, 2010 | 06:54 PM
Oldsdruid
98, ya gotta remember he's 17. True hardtops have not been made in his lifetime. For that matter in anyone under 30's lifetime.
Old Sep 19, 2010 | 06:59 PM
64Olds98's Avatar
Yeah it's hard to gage anybody's age on here, not that age has a direct effect on knowledge always I'm just 26, but he's got a start on me, I was into newer cars at that age
Old Sep 19, 2010 | 07:15 PM
70 cutlass s's Avatar
It can be. When I was 17 I would have considered my 70 just a used car, not a classic car. Correction its considered a antique now.
To the op I hope you don't find a bunch of rust under the top. Good luck.
70Post
Mar 29, 2026 01:12 PM
RATCHETMASTER
Sep 23, 2012 06:57 PM
cjprm
May 19, 2011 09:17 AM
lshlsh2
Sep 8, 2010 10:17 AM
hinz57
Aug 10, 2010 08:16 PM
