Flat top gets a top [battery]
Old Jan 19, 2010 | 01:46 PM
In my never ending efforts to get things more better. I decided I wanted to get my battery looking more origional. After seeing the prices and the 90 warranty on the repo ersatz "Delcos" I decide to try the Delco top and put it on a better battery. I've had good luck with Interstates so I bought a MT24 with 770 cold crank, painted the sucker flat black and top it off with one of those over priced plastic Delco battery tops.
I don't think it looks that bad.
Whacha think?
Old Jan 19, 2010 | 02:15 PM
ent72olds's Avatar
Registered Luser
Now you can run it in the F.A.S.T class.....
Nilsson's Avatar
Here is a tip, next time purchase a Napa battery. The stickers peel right off leaving the battery totally black.
Looks good what you did there.
Old Jan 19, 2010 | 02:37 PM
w-30dreamin's Avatar
71 & 72,now I want a 68
Cool! looks good. I did the same thing not long ago except I used a Delco battery.Didn't bother painting my though,I figured it's a Delco battery to begin with so I left the Delco ID alone. Besides,once it's in the car you can barley look down between the fender and battery to see the side of the battery where the id is.
Here's a couple pics of mine installed.
Old Jan 19, 2010 | 02:56 PM
squirell's Avatar
Govt slave
Do you know the Delco part # for the battery ?
I'm having trouble findind a flat top battery with the posts on the correct sides in my local auto parts stores
Old Jan 19, 2010 | 03:02 PM
The battery I bought is a group 24 - 6 year battery.
A couple different #'s on my reciept,
pro batt pp66 un279 19002045
hope this helps
Old Jan 19, 2010 | 06:36 PM
2blu442's Avatar
Looks Good Jamesbo!
Old Jan 20, 2010 | 03:04 AM
Yellowstatue's Avatar
Looks good but the red seems to be too bright to me should be flat red?? The Delco "eye" should be in the second hole from the pos terminal... also there should be no colour on the centre of the eye because you are supossed to see green if the liquid level is OK ! so maybe put green marker on it...
Old Jan 20, 2010 | 04:41 AM
Originally Posted by Nilsson
Here is a tip, next time purchase a Napa battery. The stickers peel right off leaving the battery totally bllack
That's what I was gonna do but I had an Interstate in the 69 drop top that went "Tango Uniform" and still had about 15 months of warranty left so I got a credit for the time remaining.
Old Jan 20, 2010 | 04:43 AM
S-W-E-E-T
One dumb question. I notice you have the "eye" one cell over. Is that correct or does it matter?
Old Jan 20, 2010 | 04:12 PM
Originally Posted by Jamesbo
S-W-E-E-T
Not a dumb question at all.
I cannot answer what would be correct because I don't know.I chose placement of the "eye" based on a majority rules basis. The majority of the pics I've seen on line show this arrangement. I have seen a few different variations but "majority rules", right?
If you are able to find out 100% for sure of proper placement,please let me know. thanks
Old Jan 20, 2010 | 05:07 PM
squirell's Avatar
Govt slave
the battery i bought is a group 24 - 6 year battery.
hope this helps
thanks !!
Old Jan 20, 2010 | 07:02 PM
rocketraider's Avatar
Oldsdruid
Actually the green "eye" didn't come about until sealed top batteries i.e. Delco Freedom came out. Up til that time the Delco Eye worked like this: if the battery had sufficient electrolyte in the cell the Eye was in, it showed dark. If the cell needed water, it was yellow since the tip of the Eye's probe was not covered in electrolyte.
The Eye came standard in some later Energizers but were available over the parts counter for both screw-in and push-in type cell caps. I have them in the Starfire and Hurst batteries.
Batteries from that era came "dry" and had to have electrolyte added and then charged before putting them in service. The battery's cells were plugged with a waxy substance that had to be removed before you could add electrolyte. The caps came in a separate bag in the shipping box. Based on that I doubt it makes much difference which cell the Eye is put in. None of the NOS Energizers I've bought had any instructions as to which cell the Eye went in.
Old Jan 20, 2010 | 07:34 PM
OLD SKL 69's Avatar
GM Enthusiast
Looks great Jamesbro!
I also bought one of those toppers and put it on top of the battery. Then the car would not start. Found out that my old, original cables had too much resistance in them. I just got my new spring ring cables and can't wait to put the topper back on. Also, thanks on the correct location of the delco eye. I was not sure where to put it.
Old Jan 21, 2010 | 05:23 AM
Thanks Rocketraider
Texas442
Mar 28, 2013 07:13 PM
w-30dreamin
Jan 9, 2010 03:19 PM
scot w.
Aug 18, 2009 09:03 AM
72 Supreme
Mar 12, 2008 06:47 AM
