What's this part for?
Old Feb 22, 2015 | 03:19 PM
kevdog442's Avatar
Member
This was one of the head bolts on my 68 455 Toro motor. What's its purpose?
Old Feb 22, 2015 | 03:34 PM
Secondary head temperature sensor, used on '68-'70 Toros, located at spot just above trans. dipstick, light green wire with white stripe, makes a yellow light flash "STOP ENGINE."
Works completely independently of the red "HOT" light attached to the sensor in the water jacket on the intake manifold.
Old Feb 22, 2015 | 03:50 PM
kevdog442's Avatar
Member
Ok thanks, never seen this before. Toronado only?
Old Feb 22, 2015 | 03:51 PM
I think some or all of the diesels may have had it, too, a decade later.
Old Feb 23, 2015 | 01:57 AM
rustyroger's Avatar
'87 Delta 88 Royale
I never came across a diesel with one of those, but then I never saw a diesel that hadn't already been rebuilt at least once.
Seems like a Citroen way of doing something imo.
It looks to me like the bottom threads are stripped or damaged?.
Roger.
Old Feb 23, 2015 | 06:45 AM
And he doesn't even get paid for giving that info.
So, I'm assuming this bolts into a dead hole on the block and it just takes temp from the block itself, or does it punch through to its own water jacket spot?
Old Feb 23, 2015 | 06:55 AM
It's just one of the lower-row head bolts.
As far as I know, the idea was to read the head or block temperature as close to the combustion chamber as possible, probably because these cars did run hot sometimes, did not have a temperature gauge, and some drivers grew to ignore the HOT light.
Old Feb 24, 2015 | 07:30 AM
cherokeepeople's Avatar
the diesels used those bolts for sensors to tell the glowplug controller if it needed to work or not and for how long.but the heads were alot taller.
Old Feb 25, 2015 | 02:42 AM
rustyroger's Avatar
'87 Delta 88 Royale
My '79 88 Royale had gauges from the factory. But mostly they didn't.
Roger.
Old Feb 26, 2015 | 01:46 PM
toymobile's Avatar
455 Buick had heat sensor that screwed into back of head to turn the AC OFF if engine temp reached dangerous level. GM tried to protect US from ourselves. LOL
IZAOLDS
Aug 9, 2010 08:36 AM
kjr442
Feb 22, 2010 06:45 AM
Texas Jim
Ninety-Eight
17
Dec 30, 2009 06:28 PM
deweirdt
Jul 21, 2009 08:29 AM
