Type of Exhaust Manifold Gasket (Cheap vs. Expensive)
(Title should be type of exhaust manifold GASKET
I have looking into exhaust manifold gaskets and there appear to be three main options for my car.
1. $9 fel pro standard (part # BMS90078)
2. $25 fel pro - high performance (part #1439)
3. $35 copper
I want the best appropriate for my car. #2 seems to be thicker and has anti-coating. I don't anyone who tried these though. Some people say copper didn't seal well for them. Worried that #1 won't last long, but heard good reviews.
3. $35 copper
Last edited by matchek; Mar 16, 2015 at 07:56 AM. Reason: questions is about gasket, not manifold
I think people use gaskets because they are used to working on Chevys. In 40 years I've never needed a gasket on a stock Olds manifold (except on my 85 and 86 307s, which came with them for the tubular manifolds). By the way, if the manifold isn't true, a gasket may not seal anyway.
How come Chevy's need gaskets and Olds don't? If not supposed to use gaskets for Olds, why can I buy one?
I have an exhaust manifold leak but maybe it is not a gasket leak. The manifold maybe needs to be smoothed then?
Do mechanics just install metal on metal or do they use any type of paste?
One more time: the FACTORY says no gasket is needed, nor did they use one. If it lets you sleep better, feel free to spend your money and use gaskets.
I talked to the mechanic. Says that most old cars he works with has leaks /imperfect block so the gasket is a safer bet, but if the both surfaces are true, metal on metal is better.
Thanks gents- learn so much here!
While I agree with Joe, if you have to use gaskets, and they just won't seal, I've had good luck with the multi-layered aluminum gaskets. Summit sells them, I believe Mr. Gasket is the maker. I have a '68 Toronado that has had the manifolds decked a few times. The aluminum gaskets were the only thing I could get to seal up permanently. Noisy exhaust manifolds are a common problem on both Toronados, and later, the GMC motorhomes that the powertrains went into. My car would blow out the Fel-pro gaskets in a matter of weeks.
It's worth pointing out that -- manifolds or headers, gaskets or not -- nothing will stay sealed if you don't do something to keep the five bolts from backing out. The factory used sheet-metal thingies on which you fold over some tabs to keep the bolts from rotating. I've had good luck using simple lock washers with grade 8 bolts.
Also, make sure you don't overtighten the center bolt, especially if you're using gaskets. Since it's not in line with the others, it can tilt the manifold and cause less gasket compression along the bottom. (Of course, it should go without saying that you should never over tighten a bolt and in fact should torque them to spec. But it's a little hard to get a torque wrench in there, especially with headers.)
aussiemobile
Feb 15, 2013 07:31 AM
I just have to sound like I know what I am talking about when I approach my mechanic.
