How long can you leave a battery charger on?
Old February 20th, 2015, 05:07 PM
Tedd Thompson's Avatar
I took the Old Man to lunch today and as I pulled out of the driveway I noticed the hood of his F150 in the up position. Seems he had left the key on and ran the battery down to flat nothing.After a short conversion I found out that the charger had been on that battery for about five days. There didn't seem to be a problem but will a extended charge (10 amps) do harm to a battery?....Just wondering...Tedd
Tedd Thompson is online now
Old February 20th, 2015, 05:11 PM
drop top olds's Avatar
For long charge times I always use a lower amp setting. From what I recall a low charge for a long time is better than a high charge for a short time. High current charges cause the solution to "boil" if I recall correctly. Actually it creates a gas maybe Hydrogen-Sulfate (?). I think its time to disconnect the charger and check to see if there is any solution left in the battery.
drop top olds is offline
Old February 20th, 2015, 06:56 PM
jensenracing77's Avatar
10 amp for 5 days is not that bad. You should be ok. How cold was it when it was completely dead? If a battery goes dead then the acid will be water. If it was water and frozen then the battery is likely junk.
jensenracing77 is offline
Old February 20th, 2015, 09:39 PM
Depends upon the charger. Automatic chargers will reduce the current as the battery charges so that the electrolyte doesn't boil. Mine is an automatic so I set it to the 10A range and leave it connected all the time; it drops to "battery tender" mode after full charge is reached..
Fun71 is offline
Old February 20th, 2015, 10:12 PM
No freezing here, it was about 75 today here in the valley, we are in a major drought and it's more like spring than winter. Thanks all, i thought it would be OK but wasn't sure....Tedd
Old February 20th, 2015, 10:13 PM
morgan
pogo69's Avatar
That will depend on a bunch of circumstances , if you put a load tester on it and it passes your good to go
pogo69 is offline
Old February 21st, 2015, 02:34 AM
gregvm's Avatar
Was it CHARGING(as per an ammeter) at 10 A for 5 days, or on for five days on a 10A RATED charger? If it was CHARGING at 10A for 5 days there is a shorted cell(s) and probably boiled those cell(s). Most modern chargers ramp down the charge rate as the battery fills. It will start out high if dead and over a few hours reduce to practically a trickle.
BTW, a COMPLETELY discharged battery(non deep cycle type) will NEVER return to 100% capacity. It damages the plates in the cells and will only return to about 85-90% capacity it had new.
Greg
gregvm is offline
Old February 21st, 2015, 06:08 AM
'87 Delta 88 Royale
rustyroger's Avatar
You won't return the acid to water either. It will not be as strong as a fully charged battery, but it will still be very acidic.
Roger.
rustyroger is offline
Old February 21st, 2015, 08:43 AM
I didn't check the setting on the charger, just pulled the wires off and started the truck, which started right up. I'll keep an eye on it for the Old Man. The battery looks dirty enough like it may be the original but I didn't check that ether...Tedd
carid
December 4th, 2014 02:55 AM
KDV
September 28th, 2014 04:22 AM
shamusj
May 29th, 2013 05:15 PM
360scamp
February 4th, 2013 11:05 PM
oggie442
Non-Olds Engines
October 14th, 2012 06:53 PM
Quick Reply: How long can you leave a battery charger on?
