Ignition Lock Cylinder Replacement
Old Feb 16, 2015 | 08:34 AM
irkennedy's Avatar
I need some help...I am replacing the Ignition Lock Cylinder on my 67 Cutlass and I can't seem to put the new Ignition Lock in. I can't find a Youtube video on a classic car install of this piece. Any help? I can't turn my car on now
Old Feb 16, 2015 | 08:57 AM
Ok, look for the little hole in the faceplate. I believe you set it to accessory and depress that hole with a paper clip.
Old Feb 16, 2015 | 09:31 AM
Octania's Avatar
battery cable disconnected
ACC position assuming you have a key
then wire [paper clip or similar] into the hole
then turn more CCW a little
Then it should come right out
reverse to install exc. that no wire is needed. Insert positioned farther ccw than ACC, turn CW to snap into place at ACC then all positions should work.
Old Feb 16, 2015 | 10:13 AM
don71's Avatar
same but different
This should do it.
Garikes
Mar 23, 2014 10:18 AM
johnnyhawthorn
Feb 12, 2014 11:47 AM
1Fastolds
Ninety-Eight
Jan 31, 2014 02:04 PM
randomarrival
Dec 22, 2012 12:28 PM
jread199
Nov 11, 2012 02:54 PM
