ignition lock cylinder removal
Old Nov 11, 2012 | 04:39 AM
jread199's Avatar
I read the the shop manual on removal, but can't seem to get it out any quick tips would be appreciated, thanks!
Old Nov 11, 2012 | 04:58 AM
Kennybill's Avatar
I have run into the same problem. I posted a more detailed explanation in a thread in Other Forum. The slot I needed to put the thin bladed screwdriver in was covered over by flashing. Follow the screw post down & push lightly, it will expose the real slot. See my other post for more info. Posting from a phone is tuff. Ken
Old Nov 11, 2012 | 05:10 AM
starfire's Avatar
Posting the year and model of the car you are asking about would be helpful.
For example, on my '68 Cutlass you need to insert the key and then put a paper clip in a hole on the front of the ignition switch to be able to remove the switch assembly. For other years and/or models there are other methods.
Old Nov 11, 2012 | 05:25 AM
lemoldsnut's Avatar
What year and model are you working on?
Old Nov 11, 2012 | 05:44 AM
jread199's Avatar
i forgot to mention it is a 1967 olds cutlass!
Old Nov 11, 2012 | 05:48 AM
lemoldsnut's Avatar
SO the big question is do you have a key? It takes the key and a paper clip. put the key in and in the little hole next to the key hole push in a paper clip that has been straigthened out, turn the key to the left kind of past the acc spot and pull. it should come out. If you don't have the key take it to a lock smith or get another ignition switch.
Old Nov 11, 2012 | 12:29 PM
Kennybill's Avatar
That year is a game changer. I was talking about a 71/72 with colunm ignition.
Old Nov 11, 2012 | 02:54 PM
jread199's Avatar
thanks for the reply's I was able to remove the lock cylinder, I used a brad nail and pliers to remove. The paper clip would not do it for me, thanks again for the help
wisniows
May 19, 2014 06:52 PM
Garikes
Mar 23, 2014 10:18 AM
johnnyhawthorn
Feb 12, 2014 11:47 AM
1Fastolds
Ninety-Eight
Jan 31, 2014 02:04 PM
randomarrival
Dec 22, 2012 12:28 PM
