Ignition lock cylinder 64 98
Old Jan 31, 2014 | 03:26 AM
1Fastolds's Avatar
Ok, so when I bought this car and joined this site, I said that I would have lots of questions.
If you don't pay attention when turning off the vehicle, it is possible to remove the key in the assy position, thus leaving the "gen" light and other assys on. My gut tells me that its the ignition lock cylinder itself, that it's worn and allowing you to pull the key out without resistance.
What do you think, and if it is a cylinder, where would you get one? The keys look relatively good, but that doesn't mean the cylinder is worn out.
Old Jan 31, 2014 | 08:13 AM
tmaleck's Avatar
I agree, sounds like the cylinder is worn out. Easy to replace. A locksmith should be able to rekey the new one to match the existing key.
Tim
Old Jan 31, 2014 | 01:46 PM
mpolds's Avatar
Ignition Switch & Tumbler
Hey, Adam, I'm here in the library, Friday, Jan. 31st, 4:30 PM eastern
time -- and I'll Call you later this afternoon, early evening -- don't like
to interrupt you at work, don't want you to get in trouble with your boss
breathing down your neck......
I have the ignition switch and tumbler (separate) brand new -- N.O.S.
U.S.A. and maybe even ++ DELCO ++ (have to look up '64 when I get
out of here -- I'll let you know later......
Craig.
Old Jan 31, 2014 | 02:04 PM
Oldskeeper's Avatar
I had the same problem with my 63 98 convertible, I started the car pulled the keys out and opened the trunk (glove box was locked) and forgot the keys in the lock. We went out for a drive and had a guy honking and honking and when he finally caught up he told me my keys were dangling from the trunk.
The following day I called Fusick and ordered new matching locks for the car, now I can't pull the key.
Steve
Garikes
Mar 23, 2014 10:18 AM
kwhitehead
Mar 22, 2014 03:44 PM
johnnyhawthorn
Feb 12, 2014 11:47 AM
randomarrival
Dec 22, 2012 12:28 PM
jread199
Nov 11, 2012 02:54 PM
