Driver side sitting 1" lower?
Old Mar 19, 2015 | 02:42 PM
plonka's Avatar
I replaced all 4 coil springs on my 76 Cutlass. After driving 40 miles or so I noticed the passenger front sits 1" higher than the driver side. Springs are seated correctly, shocks are new, and I only weigh 165lbs. You see where I'm going with this. Could it be the stabilizer end links, LCA bolts loose? I swore the front was even when I finished the install. Any ideas, Thanks!
Old Mar 19, 2015 | 02:53 PM
pogo69's Avatar
morgan
i'm wondering if it could be the springs...where did they come from?
Old Mar 19, 2015 | 03:32 PM
BlackGold's Avatar
Did you also measure the height BEFORE you replaced the springs? Regardless, the difference can be due to body mounts, metal fatigue, or simple manufacturing tolerances.
Old Mar 19, 2015 | 03:50 PM
plonka's Avatar
The springs came from a company called "Springs N Things". I measured the height before the install, but forgot the measurement. Guess I'll have to live with it, whilst the OCD in me suffers.
Old Mar 19, 2015 | 10:20 PM
If you have factory style rubber control arm bushings, you MUST have the weight of the vehicle loading the springs before you tighten the bolts completely. The rubber in the bushings can move only so far after the bolts are tightened, so if the vehicle was supported by the frame and the wheels were dangling freely, that could be why one side is now higher than the other.
70Post
Mar 15, 2014 11:28 AM
Cutlass9691
Sep 6, 2011 06:31 PM
MDchanic
Wheels and Tires
22
Aug 4, 2011 10:23 AM
classic_car_guy
Aug 7, 2006 11:04 PM
