w30 shortblock
Old Mar 1, 2015 | 12:02 PM
aqua67w30's Avatar
w30 shortblock
I have a 455 that was always thought to be pulled from a 70 w30 stick car under warranty. After looking at the numbers on the block recently I now believe it to be the warranty short block that never made it into 70 442. I was involved in the first teardown of this motor in'73 and it had the hi-compression forged pistons, 569 cam and a stick crank. the numbers on the block are stamped L70SB 3139 the 3139 is actually under the L70SB but I can't make my post look that way. I'm curious to find out how common this is.
Last edited by aqua67w30; Mar 1, 2015 at 12:10 PM. Reason: to show stamping pattern
Old Mar 1, 2015 | 01:46 PM
Like this?
L70SB
3139
If this is what's on the pad where the VIN derivative goes, clearly this motor wasn't installed on the assembly line. By federal law, the block would have been stamped with the VIN derivative from the car it was installed in.
Old Mar 2, 2015 | 04:16 PM
aqua67w30's Avatar
Yes Joe like that. I assume it means Lansing 1970 short block and the 3139 is the code for W30 4 speed.
Old Mar 2, 2015 | 04:30 PM
classicmuscle442's Avatar
Interesting, I have a block stamped very similar. L3E with 8401y underneath the L3E. Came in my '70 W30, info given to me was it was a marine or industrial?
f-85
Feb 11, 2013 06:56 AM
Apr 16, 2012 06:30 AM
BosMobile
Jun 6, 2009 04:55 PM
esisson
May 22, 2008 07:47 PM
