Bad Vibration, Part 2
Old Apr 17, 2012 | 05:01 PM
Demonator666's Avatar
Greetings. My '72 Hurst has a wicked vibration starting at 58MPH. Tires have been ballanced three times (lug-centric), new tires, new rotors/drums, new bearings, front end aligned, drive shaft ballanced, new shocks, new ball joints and bushings. Any ideas?
Old Apr 17, 2012 | 05:05 PM
coppercutlass's Avatar
Chevy budget Olds powered
you sure its not anything in the engine like a high rpm miss ? ignition? just throwing ideas out there. A buddy of mine had a similar issue turned out to be a loose flex plate / converter bolts
Old Apr 17, 2012 | 05:23 PM
Its not in the engine. I'll retorqe the converter bolts. I've consintrated my trouble shooting to the front suspension. Thanks Copper.
Old Apr 17, 2012 | 06:40 PM
Rickman48's Avatar
Someone else had a couple bent axles in a row!!
Old Apr 17, 2012 | 06:43 PM
I had a bent axle at one point and it never vibrated . That would do it too though. Quick way to find out is try to take the axle out if it fights you and seems stuck it's bent. Those axles should come out very easy if it's the bolt in type.
Old Apr 17, 2012 | 09:01 PM
my72vert's Avatar
I would try to get on a deserted road somewhere, get the car up to around 60mph, throw it in neutral and click the motor off. This would eliminate the motor and any possible torque input. Also you might be able to hear something you could'nt before.
Old Apr 18, 2012 | 01:50 PM
Good info, guys. I'm putting the car on jacks this weekend. I'll figure this thing out...once and for all!!!
Dbechtel71
Jun 22, 2015 03:27 PM
odddoylerules
Apr 21, 2014 07:54 AM
airmale
Nov 13, 2013 11:15 AM
bo1962
Jun 22, 2009 01:33 PM
okc4242
Jun 1, 2008 01:37 PM
