how do u drain the tank on a 72 cutlass
Old Mar 24, 2012 | 03:17 PM
cluelesscutlass's Avatar
I got a bunch of rust and varnish in my tank. I dropped it and expected the gas to come out the tail pipe but I got nothin, which is weird since I siphoned the gas out that way. I can get it to come out the the vent tubes though. I popped of the sending unit and also realized the tank has what looks like two cells. Any tips for my weekend project
Old Mar 24, 2012 | 04:16 PM
When I did mine, I just held it over a bucket, filler tube down. All the gas fell out.
I s'pose you could put it over a bucket upside down, so it comes out the sender hole.
Old Mar 24, 2012 | 05:45 PM
Nickthefish's Avatar
This worked for me once; disconnected the fuel line where it comes out of the frame in the front and put the hose in a bucket, took an blower and stuffed it into the fuel filler and pushed it all out that way.
Old Mar 24, 2012 | 06:12 PM
I don't think I had enough gas in it. I put a chain in it and sloshed it around, got some nasty stuff out but there is a whole lot more.
Old Mar 24, 2012 | 10:32 PM
W70442's Avatar
GM didn't design it to be emptied. They have baffles that keep the gas from coming back out the filler tube. As you've discovered, the only "direct" way is to remove the sending unit and slosh it around up side down till you get most of it out. Again, I think there are baffles that still make this method difficult.
However, if it is really that dirty inside, it needs to be professionally cleaned and sealed or just replaced. I had a place clean and seal mine when I restored the car back in 99 or so. They drilled a hole in a corner of the tank and put in a pet ****. The pet **** is neccessary not only to drain the tank of gas but for them to drain the chemicals and crud that come out when they clean it. I think they let it sit with the pet **** facing downward so that any excess sealant can drain out. Seems like it was around $100 back them.
joemo
Sep 21, 2022 04:47 AM
bob p
Mar 18, 2015 09:51 AM
1carsick
Oct 17, 2012 09:10 AM
Texas442
Jan 30, 2012 05:36 PM
MudEye
Jan 4, 2012 03:55 AM
