Other Oldsmobiles Anything not listed above, such as F-85 (1961-1963), Firenza (1982-1988), Starfire (1961-66 and 1975-80), Omega, etc.
62 cutlas gas tank replaced with 70 Nova tank
Old Jul 31, 2015 | 08:29 PM
joemo's Avatar
I was not able to find an original gas tank for a 62 cutlass convertible so the radiator shop ended up using a new replacement tank for a 70 nova. He had to make some changes but it seems to be an acceptable replacement. I have only had the car for about a week with the new tank, but so far so good.
Old Aug 1, 2015 | 05:42 AM
Can you elaborate on the "made some changes"? Obviously the filler neck needs to be moved from the rear to the driver's side. What else had to be changed?
Old Aug 1, 2015 | 07:59 AM
joemo's Avatar
I should have mentioned my car did not have the original tank. When they replaced the original tank they changed the exhaust system. The tail pipe went out the side by the filler tank instead of the back of the car. He had to change the tail pipe a little.
Your right about changing it from rear fill to side fill. So he welded some type of cover to fill the rear hole and made a new hole on the side.
I don't have the sending unit hooked up yet. I can't find the wire from the fuel gauge that goes back to the tank. The sending unit may be a different number of ohms. I think it is 0 to 95 ohms.
I know very little about cars, but the guy that did the work thought it was a relatively easy fix.
Joe
Old Aug 2, 2015 | 05:18 AM
The stock gauge needs a 0-30 ohm sender. The Nova tank has a 0-90 ohm sender.
Old Jul 23, 2020 | 04:58 PM
bigdooly's Avatar
I have a 71 98 sitting in my driveway.
I don't need the tank from it.
lmk if you think it would help.
Maybe I can pull it and post pix, time permitting.
Jim
Old Jul 23, 2020 | 05:00 PM
bigdooly's Avatar
Never mind I posted that reply to the wrong thread.
I hate cell phones.
Old Jul 24, 2020 | 07:28 AM
young olds's Avatar
I held on to a nice 62 tank for years before I got rid of my hoard of parts for those cars, always hoped I’d find someone that could use it.
Old Sep 20, 2022 | 07:18 PM
Roofman47's Avatar
I need the tank
Jim
Old Sep 21, 2022 | 04:47 AM
bigdooly's Avatar
Sorry that car is long gone. I have no tanks currently
JCMC64
May 26, 2017 10:04 AM
atsalem2
Jun 29, 2015 01:35 PM
justinj
May 8, 2014 12:44 PM
AZ455
Mar 14, 2012 06:51 PM
Gary's 2 442-S
24
Jun 7, 2010 05:46 AM
