Mystery cable
Old Apr 14, 2012 | 06:19 PM
RickH's Avatar
Mystery cable
I was working on getting my radio out of my 72 Cutlass and I had to take the A/C duct workout to get to it. Behind the accelerator pedal and directly above it, count what appears to be a cable. Any idea what it is?
Old Apr 14, 2012 | 06:26 PM
2blu442's Avatar
If your car has a TH350 transmission then you may be looking at the kickdown cable. It's attached to the gas pedal, correct? John
Old Apr 14, 2012 | 06:34 PM
Looks like a kickdown cable to me too.
Old Apr 14, 2012 | 07:43 PM
X3. Yes, it's attached to the gas pedal. The black plastic bale holds the trans kick down ball in the right position, so if your kick down is working right, leave it alone.
Old Apr 14, 2012 | 08:01 PM
RickH's Avatar
Please consider me an idiot when it comes to mechanical stuff. What's a kick down cable and it doesn't appear to be connected to anything. Maybe thecable is broken? Please look closely at that picture I uploaded.
Old Apr 14, 2012 | 08:14 PM
RickH's Avatar
Okay -I found out what a kick down cable does on the web. They are rebuilding my carb next week and I'll make sure they are aware of this problem as it appears that the cable is broken off from the foot pedal.
Old Apr 14, 2012 | 08:21 PM
2blu442's Avatar
Rick, my turn to risk sounding stupid I know some years the kickdown cable went to the carb, but other years it went from the transmission to the throttle pedal. I just don't remember which years were which.... but as I'm typing this I think yours should go from the transmission to the throttle pedal. Otherwise... there would be no need to have it attached to the throttle. I'm going to dig through the Chassis Service Manual to see if I can find the answer. Maybe another member who knows for sure can speak up?
John
Old Apr 14, 2012 | 08:40 PM
Your mystery cable goes to the transmission. There are 2 cables that attach to the gas pedal. One is for the throttle, the other is for the transmission kickdown. The transmission also takes a vacuum signal off the throttle/vacuum and the TCS automatically advances the timing for heavy acceleration.
Here is a link to the setup in my car - 1972 Cutlass S with 350/350
https://classicoldsmobile.com/forums...tml#post352299
Old Apr 14, 2012 | 08:50 PM
2blu442's Avatar
Rick, if it ends up that you need a new cable I've got some core TH350 transmissions. I'm sure I could come up with a good cable for you. John
defiant1
Feb 4, 2020 08:53 PM
rootney
Jun 27, 2014 11:30 AM
dmberendsen
Apr 10, 2013 03:18 PM
ztim
Nov 9, 2007 06:57 PM
jaco
Jan 20, 2007 06:42 AM
