Diesel cleaner?
Old Mar 29, 2012 | 04:30 AM
sammy's Avatar
Sammy70 455 Supreme
Diesel cleaner?
Is it a good idea to use diesel fuel as a cleaner? A guy was in the shop yesterday telling me to put some in the crankcase and let the motor run for 15 min, then change oil.The 350 has not run in 19 years and she is pretty gunky on the insideAny suggestions would be appreciated.
Ted
Old Mar 29, 2012 | 05:18 AM
bigD's Avatar
diesel doesn't have the lubricity that it used to have. i'd either put a couple cans of seafoam or marvel mystery oil in it if it was me.
Old Mar 29, 2012 | 05:29 AM
Rickman48's Avatar
X2 on the MMMO!!!
Old Mar 29, 2012 | 07:54 AM
Tedd Thompson's Avatar
x3,back in the day it was a common practice to flush a engine if it was sludged up but we always added a couple of quarts of regular oil to the mix....Tedd
Old Mar 29, 2012 | 07:55 AM
I would pull the valve covers first and see how bad it is. You do not want a lot of old crude deposites to break loose and run through your motor. If its all gunked up, clean it the best you can, put the valve covers back on and then do what others have suggested.
I use a quart of transmission fluid and drive it for about 3-500 miles, while monitoring temps and oil pressure.
kre
Jun 14, 2017 09:34 PM
69CutlassAlex
Dec 2, 2011 08:01 AM
al_gohi
Dec 18, 2006 02:24 PM
Rodr
Oct 8, 2006 08:54 AM
1340
Apr 2, 2006 07:13 PM
