gonna change my fuel line from the gas tank, any tips?
When I changed out the fuel lines on my '68, we found the space between the frame and the body back where the frame humps up over the rear axle to be real tight. So tight, in fact, that we loosened the body bolts and raised the body a couple of inches off the frame in the back so we could feed the fuel lines through the opening between the body and the frame at the passenger rear wheel opening, feed them forward, do a little bending to get the back part of the lines in and placed properly at the fuel tank, and fasten the new lines to the frame on the upper midd-forward part of the frame hump. Otherwise, we would have had to cut the lines and we didn't want to do that.
If the body is not on your frame, it's a lot easier!
Randy C.
Randy C.
dfire25
Jun 28, 2016 01:37 PM
Texas442
Jan 30, 2012 05:36 PM
w-30dreamin
Dec 31, 2011 05:39 PM
defiant1
Jul 10, 2011 07:41 PM
