gonna change my fuel line from the gas tank, any tips?
Old Mar 29, 2012 | 03:20 PM
cluelesscutlass's Avatar
Gonna change my fuel line from the tank, any tips or things I should know before I attempt this?
Old Mar 29, 2012 | 03:53 PM
gearheads78's Avatar
car guy
Sure....No smoking
Its simple just a short piece of hose and clamps. Easier to get the old one off the barbs with a razor or knife.
Old Mar 29, 2012 | 07:22 PM
Texascarnut's Avatar
Geezer
Use seamless stainless steel tubing.
Old Mar 29, 2012 | 09:52 PM
rcorrigan5's Avatar
Randy C.
When I changed out the fuel lines on my '68, we found the space between the frame and the body back where the frame humps up over the rear axle to be real tight. So tight, in fact, that we loosened the body bolts and raised the body a couple of inches off the frame in the back so we could feed the fuel lines through the opening between the body and the frame at the passenger rear wheel opening, feed them forward, do a little bending to get the back part of the lines in and placed properly at the fuel tank, and fasten the new lines to the frame on the upper midd-forward part of the frame hump. Otherwise, we would have had to cut the lines and we didn't want to do that.
If the body is not on your frame, it's a lot easier!
Randy C.
Old Mar 30, 2012 | 03:41 AM
My442's Avatar
Om 70-72 cars, there is a clamp on top of the frame where it goes over the axle.
No way to get it off without raising the body.
Old Mar 30, 2012 | 06:01 AM
car guy
Ooooo....You are talking about the hard line to the front of the car? Near impossible with the body on the car.
Old Mar 30, 2012 | 07:26 AM
Lady72nRob71's Avatar
Clueless, I see a big MAW heading your way.
About the size of an asteroid...
Old Mar 30, 2012 | 11:18 PM
Maw? Thanks for the feedback.
Old Mar 31, 2012 | 08:38 AM
MAW = Might as Well. When you pull off the body you might as well call it a frame off resto!
Is your hard line showing signs of leaking or severe rust?
justintiime
Jun 21, 2018 06:23 AM
dfire25
Jun 28, 2016 01:37 PM
Texas442
Jan 30, 2012 05:36 PM
w-30dreamin
Dec 31, 2011 05:39 PM
defiant1
Jul 10, 2011 07:41 PM
