Carbs & cams - AT vs. stick version ???
I've seen where certain cars had different carbs and/or cams for the stick vs. AT cars.
Why? / What is the difference ?
Does an AT car require something extra/less to compensate for the TC drag at idle ? Or ?
There are carb/cam combos for 442s based on stick or AT, but SBO cars (exc. W-31) all got the same carb/cam regardless of trans. Does this only apply to higher powered engines ? Or was it just a $$ issue for the SBOs ?
Just wondering....
Just wondering....
Some cars supplied with A/T had a slightly more powerful engine than stick models in the '50s & '60s.. This was to compensate for the power loss through the auto trans.
Automatics are best suited to engines with lots of low rpm torque, could be the cams were profiled for this in the the auto versions.
Roger.
Roger.
Think it has something to do with vacuum the perfomance stick shifts required less vacuum as they had less items that needed vacuum to work so the cam was a bit better. The automatics had more items that needed the vacuum so the cam was milder. Could be other reasons also.
There are a number of factors. Idle speed, vacuum, performance, strength of the AT, etc. For example, in 1968-69, the AT 442s got a milder cam (and only 325 HP) as compared to the MT cars (with 350 HP). On the other hand, the beefed TH400 in the W-30 cars allowed both AT and MT W-30s to use the same cam and thus have the same 360 HP rating, but neither power brakes nor A/C were available. Interestingly, the 1969 W-32 cars used the same cam as the MT cars and had the same 350 HP rating. Power brakes were available on the W-32 but not A/C (though the latter may have been due to problems routing the O.A.I. hose around the A/C compressor - yes, I know the H/Os had A/C in 1968).
Then, there's the 1970 model year, where the MT W-30s got the 328 deg cam and were not available with power brakes or A/C, while the AT W-30s got a milder cam and could have PB and A/C. Of course, Olds just lied about the two having the same HP rating...
This is what I was thinking. That somehow the MT combo had a narrower/'peakier' power band due to having 4 gears as opposed to 3 wider gears in the AT (M20/21 vs. TH350/400).
-Eric
Ahhh...Interesting idea....but was redline different between the AT/MT config ?
Eric is also correct, since A/C cars were limited to 3.23:1 gears, allegedly due to the compressor RPM limit.
Ever look at how long that run of fan belt to the compressor is?
Considering the average driver's propensity for routine maintenance - both then and now - if you imagine that belt poorly adjusted, whipping around under load at 6,000 RPM, it just isn't pretty. Not allowing A/C is a good way to avoid the warranty department having to have that argument a few thousand times.
5998DownUnder
Nov 24, 2014 05:46 AM
rctoyguy
May 20, 2014 03:38 PM
