Parking & dash lights went out...
Old Aug 19, 2011 | 08:35 AM
Southern_Hospitality's Avatar
Good morning OLDS enthusiasts. I have a bit of an electrical problem. My parking and dash lights went bye-bye while I was driving last night. A mechanic is estimating $98/hr to check it out (I ran for the hills, lol). Can you guys help me do some troubleshooting. I tried to attach a pic. Which fuse should I check?
Old Aug 19, 2011 | 09:44 AM
rocketraider's Avatar
Oldsdruid
Assuming this is the car in your avatar, there should be one labeled "TAIL" that feeds the park/tail/marker lamp circuit in the headlight switch. Thru the switch I think it also feeds the INST LPS fuse. I don't have my wiring charts handy so right now that's as specific as I can get.
Sometimes fuses blow from old age, but I'd check all the wiring closely. Odds are the trouble is at the rear of the car.
Old Aug 19, 2011 | 09:52 AM
Lady72nRob71's Avatar
Replace the fuse or check both sides with a volt meter. 12V should be on both sides with light switch ON. The fuses sometimes break internally and not actually 'blow'.
Check to see the hood lamp connector and wire (brown) near the brake booster did not get pinched or shorted to ground, a common occurance.
MarineJusten
Jul 16, 2014 03:30 PM
scooter123
Sep 28, 2013 07:32 PM
cintr113
May 29, 2011 07:04 PM
bigwillystyle
Brakes/Hydraulic Systems
Sep 16, 2010 10:56 AM
veltboy618
Mar 30, 2009 04:30 AM
