Gasoline in the oil
Old Jul 31, 2011 | 09:50 AM
tru-blue 442's Avatar
Old School Olds
Gasoline in the oil
I was wondering if anyone had ever had this happen:
Rebuilt 455, new fuel pump,oil pump, etc. The carb
flooded a few times after it was run several hours.
Let it cool down, checked the oil the next day and it
had enough gas in the oil, you could smell it. Didn't seem to
be enough to go above the full mark. I never had one do this
to me before. Any thoughts are welcome.
Old Jul 31, 2011 | 10:39 AM
jaunty75's Avatar
Any thoughts
Yes, and they're all bad. Fuel leaking down past the piston rings?
Gasoline will dissolve the oil and reduce its effectiveness. It's not just a matter of that there's not enough gas in the oil to push the level above the full mark. You need to get that gasoline out of there, figure out how it's getting in there, and stop it.
Old Jul 31, 2011 | 11:28 AM
67442nut's Avatar
If it's a quadrajet carb, it's possible the plugs in the metering rod wells are leaking, allowing fuel to
drain out overnight. I've had this happen before.
This can be corrected by knocking the plugs out and making a "cap" over the well with epoxy.
There may be better methods. This worked for me.
There used to be a little kit available for this, but, I didn't like it.
It consisted of 2 brass replacement plugs with O-rings to replace the old plugs.
A piece of high density foam precut to the shape of the well was supplied to hold the plugs in place.
Didn't seem to work very well, so, I tried the epoxy method which seemed to do the trick.
As Jaunty said, fix it soon. A variety of damage can occur. Cylinder walls can be damaged.
I wouldn't drive it anymore until this is corrected.
Old Jul 31, 2011 | 11:58 AM
66400's Avatar
If it not the carb it's possible for the fuel pump to leak fuel into the crankcase.
Henry
Old Jul 31, 2011 | 05:26 PM
Old School Olds
Thanks guys. I will check all the above.
Old Jul 31, 2011 | 09:14 PM
cluelesscutlass's Avatar
I just had a similar problem, check out the thread "oil smells like gas"
Old Aug 2, 2011 | 06:34 PM
Old School Olds
Thumbs up Got it!
It was the fuel pump. Brand new Autoz#@! JUNK!
I knew I should have gone NAPA
Thanks for all the input fellas...
Old Aug 3, 2011 | 06:04 AM
Glad you got it figured out!!!!
RDG
Dec 23, 2020 05:12 PM
554drholiday
Nov 18, 2010 05:27 PM
njot33
Sep 25, 2009 09:07 AM
jaco
Jan 28, 2007 12:54 PM
