Is this for real and can somebody explain?
Old Mar 16, 2026 | 01:00 PM
scrappie's Avatar
Although it wasn't explained in detail in the video, I'm thinking the ethanol mixes with the water removing it from the gasoline so the water left has ethanol mixed in? right?
Small engines right?
Just went down a rabbitt hole........
Old Mar 16, 2026 | 05:17 PM
VC455's Avatar
Barely Registered
Ethanol mixes with gasoline to form a solution.
Water will not mix with gasoline.
Ethanol mixes much better with water than with gasoline. So, when you give the ethanol a choice, it will choose to go to the water layer.
The more water you use, the more ethanol is removed.
It's necessary to use enough water to attract most of the ethanol. The presenter said he used a bit more water than necessary; that removed a tiny bit more ethanol.
It was well that he let the mixture sit overnight, because otherwise any residual water in the gas layer could settle out later. That helps the StaBil prevent future settling.
Old Mar 17, 2026 | 06:09 AM
Oldsguy's Avatar
Past Administrator
I saw that someplace before, probably on UTUBE. It makes sense to me but I am sure glad that in Texas all you have to do is drive to a Buc-ee's and pump it.
Old Mar 17, 2026 | 07:47 AM
jaunty75's Avatar
What a bunch of bullshit. Just because you CAN go through his rigamarole to remove the ethanol from gasoline doesn't mean that you SHOULD or NEED TO.
1. Every one of the items he mentions (lawn mowers, weed-wackers, snowblowers, outboard motors, whatever) that run on gasoline were all DESIGNED to run on gasoline containing 10% ethanol. That's been the case for decades. You are gaining NOTHING by going through his alchemy. The devices will run just the same, and they aren't harmed by using 10% ethanol gas. He talks about some of his equipment sitting over the winter. In that case, drain the tank instead of leaving gasoline, ethanol-free or not, in it all winter long.
2. You certainly would not follow his procedure to make gasoline for your vintage car, which is something that you might actually legitimately want to run on pure gasoline, because his system works for small batches (a few gallons), not the tens of gallons needed to fill an auto fuel tank every time it needs a fill-up.
This is a guy with too much time on his hands. I have a better idea. Get a haircut.
Old Mar 17, 2026 | 09:29 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
We still have non ethanol 91 Premium gas here. I run it in my Olds. Nothing wrong with 10% ethanol fuel, IF it doesn't sit for long periods. Problem is here, things can sit for 6 months, leaving green carbs and poor running. We have seen issues with old 10% ethanol 87, I delivered gas and diesel. But a customer had poor running with non ethanol in his 4 wheelers. He switched back to 10% ethanol 87 octane, problem solved. He figured they were tuned for E10 and ran too rich on non ethanol.
Old Mar 17, 2026 | 09:50 AM
acavagnaro's Avatar
Thumbs up
Originally Posted by jaunty75
this is a guy with too much time on his hands. I have a better idea. Get a haircut.
nice!!
Old Mar 17, 2026 | 01:28 PM
GN1220's Avatar
Everyone I've ever talked to that deals with small engines says to run ethanol free gas, even the STIHL salesman. I've been doing it for years now and have never had a carb issue since. I'll stick to my Quik Trip ethanol-free gas for my small engines; mowers, blower, trimmer, snow blower, chain saw and pressure washer. I never drain anything either, just top it off and they all never fail to start right up when needed. And my two mowers and the washer are 4 stroke, all else are two-stroke, if that matters.
Old Mar 23, 2026 | 10:58 AM
JRSL69's Avatar
J.R.
FWIW, I add the recommended amount of Seafoam to the remaining fuel and run the engine for a few minutes before storing my piece of equipmnet for the season. Never had an issue and have been doing it for years.
Old Mar 23, 2026 | 11:51 AM
I only run 100% gas in my mower. At the end of the season I drain the tank.
My Pullin' Pro chainsaw from Horrible Freight was such a PITA that I sold it for $20 and bought an electric Makita chainsaw.
alsmith787
Aug 23, 2024 06:20 PM
bw1339
Oct 15, 2023 09:00 AM
Drum
Jan 5, 2019 12:55 PM
starfire
Non-Olds Engines
Sep 19, 2014 05:25 PM
rustyroger
Tech Editor's Desk
Oct 10, 2013 06:49 PM
