97 88 LS Brake lights
Old May 20, 2026 | 10:56 AM
aphelps's Avatar
Replaced the bulbs
The Blinks work and the hazards work fine
Nothing happen when I hit the brake for lights
I have replaced the brake switch twice in the past 3 years
Not sure what is going on.
Please help!!
Old May 20, 2026 | 11:30 AM
442Harv's Avatar
Do you have power to the switch? If so, may be another bad switch.
Old May 20, 2026 | 12:14 PM
aphelps's Avatar
Yep power to the switch
Old May 20, 2026 | 12:31 PM
torotoyguy's Avatar
And, do you get power out of the switch?
If not, it's a bad brake light switch. If yes, I think the next component down the line would be the turn signal switch.
Old May 20, 2026 | 12:41 PM
66_Jetstar's Avatar
Could also be the multifunction switch. Used to replace those all the time in GMs of that era. Thats the turn signal switch assembly.
Old May 20, 2026 | 01:42 PM
^^^THIS^^^
Unfortunately, you'll have to find one in the salvage yard if it's bad. This is also the cruise control and wiper switches. It gets quite a bit of use as I remember from my 96 98.
Old May 20, 2026 | 02:13 PM
aphelps's Avatar
yes power goes out
So looks like it is pointing to the turn signal switch
Anyone have and good pointers in fixing that?
And links to get one?
Old May 20, 2026 | 03:59 PM
You can use this search engine to see if there are any Oldsmobiles or Buick LeSabres in a salvage yard near you.
https://www.car-part.com/
Apparently, you can still get the innards of the switch that goes in the steering column from Rock Auto. I didn't see a listing for the stalk itself though.
Old May 20, 2026 | 04:09 PM
aphelps's Avatar
thanks
gtucker
Oct 5, 2025 05:43 AM
AlyPeppers
Jan 25, 2024 01:07 PM
1970_Delta_88
Sep 29, 2021 04:38 PM
starfire
Apr 20, 2013 03:06 PM
Deluxetrashe
Jan 1, 2007 05:02 PM
