Recent family acquisition...
Old Feb 10, 2026 | 06:15 PM
72455's Avatar
1972 U code Supreme
So it looks like my stepson snagged a relic...a one owner 6K miles '63 F85.
Would anyone care to decode the cowl tag?
Old Feb 10, 2026 | 06:25 PM
lshlsh2's Avatar
71 cutlass convertible
Very nice. The hardest part might be getting it out.
Old Feb 10, 2026 | 07:46 PM
Charlie Jones's Avatar
Phantom Phixer
I'll give it a shot.;
Style 62-3119 = 1962 F-85 Deluxe four door sedan.
06A = body produced in first week of June 1962.
Body LA 11195 = made at Lansing MI.
Trim 951 = Medium gray cloth with dark gray accent.
1962 Oldsmobile – Tagged "model-F-85 DeLuxe 4-Door Sedan" – SMS Auto Fabrics
Paint P-C = Lower color Pacific mist metallic with white top.
1962 Oldsmobile
Acc S = ???
Old Feb 10, 2026 | 08:11 PM
69CSHC's Avatar
Nice, congratulations to him. Like the color very much, and don't think I have ever seen that air cleaner housing till today.
http://gtcarlot.com/data/Oldsmobile/...-64232620.html
Old Feb 10, 2026 | 08:27 PM
Is there documented proof of mileage? Looking at the odometer with the numbers not lining up, it might have gone around once.
Old Feb 11, 2026 | 04:44 AM
zl1 camaro's Avatar
I agree, that engine looks like it has a lot more then 6000 miles for sure. look at the oil around the filler tube & valve cover.
Old Feb 11, 2026 | 04:53 AM
What a cool find!
Check the brake and accelerator pedal too. If it's rolled over at least once they're probably pretty worn.
Old Feb 11, 2026 | 05:59 AM
Nice. Two bbl motor with the "soup pan" air cleaner.
Old Feb 11, 2026 | 06:14 AM
BlueCalais79's Avatar
Whatta find! guaranteed this car is going to clean up nice, well done!
Old Feb 11, 2026 | 08:52 AM
torotoyguy's Avatar
So, I'm confused by the exterior body color (metallic light blue) versus the underhood firewall and fenders in metallic "pink"?
Old Feb 11, 2026 | 09:01 AM
Scroll back up and look at who posted which photos. The OP posted photos showing the engine compartment with Pacific Mist inner fenders, which match the paint code on the cowl that that he also posted (P-C is Pacific Mist lower body color and Provincial White upper). The engine compartment photos with the Sunset Mist inner fenders were posted by someone else and is not the OP's car.
Old Feb 11, 2026 | 09:06 AM
Dave - He did, indeed. Very nice.
Old Feb 11, 2026 | 09:13 AM
JohnnyBs68S's Avatar
Soup "pan"? More like a soup kettle. That thing is huge. Was it an oiled filter arrangement? Interesting that it has an "TE" at the end of Rocket, kinda infers that it's a small displacement V8. So would this be a 215 N/A V8 or something else?
Concur that the ODO looks like its rolled (either forward or back), but overall that is a great, very salvageable find.
Old Feb 11, 2026 | 09:14 AM
Bigmikey65's Avatar
Great find !
Old Feb 11, 2026 | 09:18 AM
^^x2^^ Odometer looks like it's rolled over (at least) once.
Old Feb 11, 2026 | 09:24 AM
Looks like it has PS & no PB...I think it'd be remarkable if it did have PB.
Old Feb 11, 2026 | 09:27 AM
acavagnaro's Avatar
6 or 106??
Old Feb 11, 2026 | 12:06 PM
torotoyguy's Avatar
Open mouth - insert foot. I knew there'd probably be an easy answer, but I didn't scratch my head hard enough.
Thanks for putting me straight.
Old Feb 11, 2026 | 01:26 PM
69455's Avatar
Any thoughts of selling it ?
Old Feb 11, 2026 | 01:35 PM
1969Hurst's Avatar
Indeed, I bet those seats are going to come out great as well!
Old Feb 11, 2026 | 01:47 PM
A dated (2012) discussion but some nice images >>> https://www.britishv8.org/smf20/index.php?topic=33908.0
Old Feb 11, 2026 | 02:59 PM
There's a conventional paper element inside. I've never actually understood why Olds felt the need for this total enclosure of the 2bbl carb. The intake has a matching ridge that has notches for the linkages and fuel/vacuum lines.
Old Feb 11, 2026 | 03:03 PM
The PB booster is a bellows unit under the dash that acts on the brake pedal. That was not uncommon at the time, and there wasn't room under the hood for a diaphragm style vacuum booster. However, I don't see the big metal vacuum tank under the hood, so no, it likely doesn't have PB. These cars only weigh 2,700 lbs, so they don't need power brakes anyway. They don't need PS either.
Old Feb 11, 2026 | 03:12 PM
...I don't see the big metal vacuum tank under the hood, so no, it likely doesn't have PB. These cars only weigh 2,700 lbs, so they don't need power brakes anyway. They don't need PS either.
Cars w/ the Dolomite tires likely had no PB, those w/ Granite probably received PB. Don't take me for granite.
Old Feb 11, 2026 | 07:05 PM
6 or 106??
Put me down for 106. I'm surprised OP didn't come to the same conclusion.
Old Feb 12, 2026 | 03:38 AM
I'll bet that enclosed carb in air cleaner had something to do with the Turbo's they were developing?? So they could fully pressurize the carb like some of those older Turbo kits did? Do you know, Eric??
Old Feb 12, 2026 | 04:15 AM
jensenracing77's Avatar
Nice! This is a 1962 and not a 1963 though.
Old Feb 12, 2026 | 04:24 AM
It wasn't anything for the turbo model but I do have a document on why they did this. I will see if I can find it.
Eric
Old Feb 12, 2026 | 05:42 AM
Eric
I'd be interested in seeing that as well, Eric.
Old Feb 12, 2026 | 06:29 AM
I feel like it is in my Heritage Center documents I got but not sure. I did read something on it somewhere. I just need to find it. If it is from the Heritage center it should not be hard to find. I will look tonight.
Old Feb 12, 2026 | 02:07 PM
  #31
I found it but it is not as exciting as I hoped it would be, lol.
Old Feb 13, 2026 | 07:32 PM
  #32
shiftbyear's Avatar
On the contrary, information like this intrigues me. Imagine a group of engineers standing around in their lab coats tweaking the design of this intake & air cleaner. Fascinating!
Old Feb 14, 2026 | 03:40 AM
  #33
Seems like a regular style air filter would have cooler air in it than one that its directly on the hot engine manifold..... Yes that is interesting!
Old Feb 15, 2026 | 09:32 AM
  #34
72455's Avatar
1972 U code Supreme
He picked it up yesterday and gave it a bath today.. looks to be in really good shape.
Old Feb 15, 2026 | 10:10 AM
  #35
Dave - Looks nice.
Old Feb 15, 2026 | 11:00 AM
  #36
torotoyguy's Avatar
That actually looks awesome, possibly worth keeping unrestored - just clean, clean, clean, and then polish, etc. I know there were some interior issues, but even that might clean up real good. I'd love to see it at Olds Club national meet down the road.
Congrats on excellent find.
Old Feb 15, 2026 | 02:39 PM
  #37
davek1661's Avatar
That is seriously awesome! What a great find! Do you know how long it has been in storage? Has your son tried to start it yet?
Old Feb 15, 2026 | 04:29 PM
  #38
WOW! That cleaned up nice. I just noticed, it has the 15 inch wheel option. Those 15's are hard to find and the trim rings are even harder to find. I highly recommend not taking the trim rings off the wheels unless absolutely necessary. They like to crack at the factory welds. When and if you do take them off, pry them off on the opposite side of the seam if you can see the factory welded seam. You can see it from the back side but harder to find when mounted to the wheel.
Old Feb 15, 2026 | 04:31 PM
  #39
I have several 61-63 parts cars if you find anything you need.
Old Feb 15, 2026 | 05:09 PM
  #40
Phantom Phixer
It must have been quite a project getting enough trash out of the way to get it out of that garage.
Nice find! Looks like it will shine up nicely.
