Vacuum Spec 442 w/455
Old Apr 11, 2026 | 06:32 AM
OLDsBARRY's Avatar
know of a FACTORY Spec of Inch Of Vac for 70s up on the 442 (455)
Have looked at every piece of FACTORY Lit i can find NOTHING.
Old Apr 11, 2026 | 07:06 AM
Generally you should expect between 17”Hg - 21”Hg with stock cam. Reading should be rock steady.
Old Apr 11, 2026 | 08:34 AM
6C-7 of your Chassis Service Manual. Took me longer to type this than to find it.
Old Apr 13, 2026 | 06:22 AM
Jungle Cat's Avatar
The W30 4speed made less vacuum than that because of special cam. That’s why you could not get AC or power brakes on a 4 speed w-30 on 1970 anyway. Vacuum gauges are cheap. It’s interesting to check you engine to see what your vacuum reading really is. More radical cams the vacuum needle will bounce a little. More street type cams will show a steady reading.
Old Apr 13, 2026 | 07:00 AM
zl1 camaro's Avatar
Originally Posted by vintage chief
generally you should expect between 17”hg - 21”hg with stock cam. Reading should be rock steady.
this @ idle^^^^^^^^^^^^
Chuxter
Feb 6, 2024 03:50 AM
oldsonharmont
Jan 13, 2018 09:13 AM
jalopi42
Jul 16, 2016 05:18 AM
Phil Glass
Jun 1, 2010 09:04 PM
Phil Glass
May 29, 2010 12:54 PM
