Vacuum Spec 442 w/455
The W30 4speed made less vacuum than that because of special cam. That’s why you could not get AC or power brakes on a 4 speed w-30 on 1970 anyway. Vacuum gauges are cheap. It’s interesting to check you engine to see what your vacuum reading really is. More radical cams the vacuum needle will bounce a little. More street type cams will show a steady reading.
